Failing U Joint sounds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Apr 14, 2013.
  1. Apr 14, 2013 at 6:50 PM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    Is a loud squeal from the rear end under full throttle on the road a sign of a bad joint? The intensity and rhythm of the squeak/squeal is directly proportional to the rpm level.
  2. Apr 14, 2013 at 6:55 PM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Burning tires again?
  3. Apr 14, 2013 at 6:58 PM
    USNavyTaco
    Goose Creek SC
    NO. I wish though, this is an issue with something in the driveline, not an issue with too much torque. :D
  4. Apr 14, 2013 at 7:02 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Sounds like your carrier bearing is shot. That's what mine sounded like when mine went out.
  5. Apr 14, 2013 at 7:03 PM
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    4Runner Trail Edition
    Skids, sliders, 2" lift
    Don't think so. Perhaps the input bearing on the differential--or something inside.
  6. Apr 14, 2013 at 7:04 PM
    USNavyTaco
    Goose Creek SC
    How hard/expensive is it to replace?
  7. Apr 14, 2013 at 7:05 PM
    oldracer
    oldracer Well-Known Member
    Yes a squealing or chirping sound on a pull, not necessarily full throttle.
    But not directly proportional to RPM, it would be directly proportional to road speed,; because this is past the transmission. You could change RPM by changing gears. The sound wouldn't matter as to what RPM it was, as the rear axle is spinning at road speed.
    And your rear drive shaft is spinning at road speed; because you do not have a rear axle that can change ratios.
    But Yes, a chirping sound under power to answer your question.
    It is probably only dry, if you catch it quickly, you may be able to save the joint. Lube it. If you see rusty dust at the u-joint, you found your trouble.
    Note: a front CV joint will chirp, make noise, vibrate, while the steering wheel is turned sharply to one side or the other; if is bad.
    oldracer
  8. Apr 14, 2013 at 7:09 PM
    USNavyTaco
    Goose Creek SC
    its not related to road speed, i can be going 80 and its fine, its just bad on throttle past about 4500. If I pull out of a parking lot and give it the beans it will squeal. If I slam it when im going 70 down a freeway, same deal. it will squeek/squeal until the rpms drop back down
  9. Apr 14, 2013 at 7:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like the serpentine belt.
  10. Apr 14, 2013 at 8:07 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I bought an aftermarket beefy one for $100. But you either have to be 4wd or get a slip joint added to your driveshaft if you are 2wd like me. I had a driveline shop do it.
    Otherwise just get a stock one. But figure out the problem first.
  11. Apr 15, 2013 at 6:05 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    Try it in 4wd. The front wheels will take a load off the back. If you don't get as much noise or it dosn't do it then you have something after the transfer case. If you don't have 4wd, a good inspection of the drive shaft. most likely the carrier bearing.
