failure to accelerate
Discussion in 'Technical Chat' started by strip, Jul 18, 2013.
  1. Jul 18, 2013 at 7:05 AM
    strip
    strip [OP] Well-Known Member
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
    I searched everyway I know how and could not find a similar thread.
    Yesterday when I stepped in to the throttle to pass a car in my 07 v6 auto double cab, the truck felt like it died, it went to nothing and then it felt like it down shifted then slowly began to pull again a few seconds later. it was sort of like the worst engine hesitation I have ever felt. anyone ever had this issue? no check engine lights are on or anything.
  2. Jul 28, 2013 at 9:40 AM
    strip
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
    any thoughts on how to trouble shoot this?
  3. Jul 28, 2013 at 9:43 AM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
  4. Jul 28, 2013 at 9:44 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    MAF sensor maybe?
  5. Jul 28, 2013 at 10:00 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Could the truck be in limp mode? I think that would throw a check engine light. When you turn the truck ignition to the ON position, do the warning/check lights come on?
  6. Jul 28, 2013 at 10:10 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    when was the last time you cleaned your injectors/fuel system?
  7. Jul 30, 2013 at 12:23 PM
    strip
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
    No check engine lights, I have never cleaned my injectors or fuel system. 82K miles, but I bought it used and have no ideas what the PO did to it. If I take off from a stop and accelerate hard through a few gears, I have no issues and it runs strong. it only occurs when I try to accelerate from a cruising speed and it doesn't matter how slowly I push the pedal down, once it gets to about 2/3 throttle it happens. Its like the truck dies, then slowly starts to pick back up in a lower gear. But once it starts picking up it runs strong. It almost seems to me to be an issue when the truck down shifts. Is there something in the programming that stunts the engine while the transmission downshifts? could my transmission be down shifting too slow and causing this stunt to prolong into a full blown momentary stall? Of course it could be that when it down shifts its a faster rpm gain and the engine could just be rejecting the gain for some reason I can not comprehend.
  8. Jul 30, 2013 at 12:42 PM
    Dastick
    Dastick Member
    Alberta, Canada
    '08 Dbl. Cab LB TRD Sport
  9. Jul 30, 2013 at 2:56 PM
    strip
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
    Very interesting! I am not sure my truck has that engine cut off thing, I just power braked it at a red light the other day trying to see if I could get it to reproduce the problem at a slow speed. But I will definitely keep the break light switch in mind. Thanks
  10. Jul 31, 2013 at 12:31 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be a faulty pedal position sensor. Should be able to test that with a multi-meter, if its a variable resistor.
  11. Jul 31, 2013 at 2:36 PM
    strip
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
    guess I need to go buy me a service manual. was hoping to not need one for a while. Thanks for the tip.
