Faint beeping from Audio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kauaihunter, Jun 19, 2021.
  1. Jun 19, 2021 at 1:26 PM
    kauaihunter
    kauaihunter [OP] Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Installed an amp and all new speakers plus sub in my 21. There is a faint beeping noise that I hear even with the audio turned off and does not increase in volume, just gets lost in the sound when music is played. I’m gonna try and shorten the ground wire and try another remote source to turn on the amp.
    Right now I’m tapped into the 12v from the USB ports in the center console. This is the first system I’ve worked on in a long time and other than that, it functions fine. Just a little annoying. It only happens if the engine is running.
    Back in the days of carburetors, the only thing we ran into was alternator noise.
    Wondering if someone else has experienced this? I did search the forum and have read a lot of the audio threads.
  2. Jun 19, 2021 at 1:28 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    Check the wire between the battery negative and the body.
    Without it you will hear the dash light dimmer buzz, LED headlight noise if you have them, sounds from anything plugged into the 12v outlets, blower fan noise, trailer brake whine, etc.
    kauaihunter[OP] likes this.
  3. Jun 19, 2021 at 1:31 PM
    kauaihunter
    Jay
    Ok thanks, I will take a look.
  4. Jun 19, 2021 at 2:15 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what amp? because i don't know of any wiring issue that will cause a beeping noise. if it's a constant tone/hum, that's a different story though.
  5. Jun 19, 2021 at 3:08 PM
    kauaihunter
    Jay
    TTunes 5 channel
  6. Jun 19, 2021 at 8:43 PM
    kauaihunter
    Jay
    Checked the ground from the battery to the body and removed it, sanded some paint off and bolted it back on.
    Disconnected my remote wire coming off the USB power in the center console and ran another temp power wire to turn on the amp.
    Shortened my amp ground wire.
    No difference. What I have learned is along with the distinct but very faint beeping sound,there is also a slight hum I guess you could call it when the amp turns on. Also, I thought the beeping only happened when the truck was running but after looking and listening closer, it does happen with the key in both the ACC and On positions, engine running or not.
    It only sounds like it’s coming from the right front speaker area. Again, there is a distinct beeping, although very faint but that’s what caught my attention early on. Does not affect the sound quality and it does not get louder with volume. Just a weird annoyance when driving and the head unit is turned off or sometimes I notice it between songs.
    So I’m figuring it’s definitely the amp producing this for whatever reason.
    Unsolved mystery but so far, it hasn’t caused any problems and it’s already been about 4-5 months.
