Faint buzz/pulse in brake pedal in breaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SK bassin, Jan 8, 2017.
  1. Feb 3, 2017 at 11:01 AM
    Zoop
    Zoop Well-Known Member
    Yeah my plan is to keep having them put it in the notes in case anything happens, from what I've read on other manufacturer forums (also a 4-Runner forum) is that it may be related to the brake-booster kicking in. "lag between the voltage regulator and the PCM communcating" was another item of interest on a GM forum.
  2. Feb 6, 2017 at 6:14 AM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    I drove over 200 miles in my father-in-law's '15 land cruiser this weekend which has a similar pump/accumulator assembly. There was no noticeable feel in the brake pedal when the pump switch on though I could hear a similar faint buzz/hum during the pump spinup.
    So I'm curious to know why the pump engagement/disengagement feel in the brake pedal is so pronounced on the tacoma. I'm also curious to know if this is something that all TRD OR's exhibit or if it's something that's more pronounced in certain examples.
  3. Feb 6, 2017 at 6:52 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    cheaper components and/or the design is less refined would be my guess
  4. Feb 7, 2017 at 8:28 AM
    Zoop
    After digging around the internets, it looks like they used to put 27F batteries in with tow packages (1st/2nd gen), popped the hood and I have a 24F in an Off Road w/factory tow package. Anyone else have this? I wonder if its a way for them to cut cost, it seems the 27F has a larger storage capacity which makes me wonder if when the booster, lights, all the electronic shit going on in the truck is where I'm getting the power suck from and the 24F is just not beefy enough to handle it.
    Any thoughts?
  5. Mar 25, 2018 at 9:30 PM
    Erklsim
    Erklsim Well-Known Member
    2017 QS Tacoma DCOR 4x4 MT
    Just thought I’d post here if anyone else has had any input.
    I’m getting the vibrating pedal :( it seems to have just started at 9,000 miles. So why now?
    When I push the pedal down, key on, engine off. It hums for a good while.
    If I start the car it will vibrate for 1-2 seconds every 2 pedal pumps.... weird.
    Then it will happen when coming to almost any stop.
    This is super annoying, has anyone had any success with the dealer. Is there any fix?
    bubbakingaroo likes this.
  6. May 14, 2018 at 6:38 PM
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    Same shit on my new 2018 Tacoma Off Road. I'm returning it back. I will b looking into a new truck. Ford, GMC, Dodge, or a Chevy. I'm soo sad that Toyota are being lazy now.
  7. Jun 15, 2018 at 8:56 PM
    Lima_Delta
    Lima_Delta Well-Known Member
    PacificNW
    2015 TRDOR AC MT
    I have a 2015 TRDoffroad. It just started buzzing or at least i never noticed in before now for some reason, like every other time I step on the brake. I took it in early just for a quick look see, and they thought it was normal.
    The only time I heard it before is just starting the truck, or turning the key to accessory you would hear it spin up.
    Still under warranty, but with out a dash light on or engine light—they seem to think it was a non issue. I am not so satisfied with that answer.
  8. Feb 20, 2019 at 7:00 PM
    bubbakingaroo
    bubbakingaroo Member
    2019 TRD OR 4x4
    Brand new 2019 Tacoma off road. Break pedal has slight buzz every other break press. Happens even when car is in park so not rotors. Apparently this is because of electric breaking system? Very annoying.
  9. Feb 21, 2019 at 6:48 PM
    bubbakingaroo
    2019 TRD OR 4x4
    Buzz. Break. Buzz. Even in park bzzzzd. Very annoying ! Don’t want my break pedal going buzz every second break. It is faint and subtle but still cmon.
  10. Feb 22, 2019 at 5:48 AM
    Tig3r_Bit
    2018 TRD OR 4x4
    @bubbakingaroo you'll get use to it. Totally normal. I was very annoyed by it also.
  11. Feb 22, 2019 at 10:17 AM
    bubbakingaroo
    2019 TRD OR 4x4
    Thanks hope so. Everything else about car is sweet. Just not used to the buzz hah
