Faint clunking sound 2021 Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Nov 8, 2020.
  1. Nov 8, 2020 at 6:42 PM
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    I just got my 2021 TRD Pro, lunar rock. At low speed there is a very faint clunking sound. I can't tell if its coming from the front or rear. Wondering if anybody else's 2021 is doing this....
  2. Nov 8, 2020 at 6:43 PM
    soggyBottom
    soggyBottom Well-Known Member
    Need more info. When are you hearing the sound?
  3. Nov 8, 2020 at 6:44 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Gotta describe it further
    when does it happen, is it sporadic or rhythmic, increase with speed etc
  4. Nov 8, 2020 at 6:45 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Only at low speeds, like in a parking lot, forward and reverse, turning or going straight doesn't matter
  5. Nov 8, 2020 at 6:45 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Sporadic, over smooth pavement, most noticeable at parking lot speeds.
  6. Nov 8, 2020 at 6:46 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Brake pad slap? Does it happen when switching forward to reverse or vice versa?
    tcjacado likes this.
  7. Nov 8, 2020 at 6:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Usually its the TRD skid plate that needs a subtle adjustment.
  8. Nov 8, 2020 at 6:47 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Doesn't seem to matter.
  9. Nov 8, 2020 at 6:47 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Can you give details?
  10. Nov 8, 2020 at 6:48 PM
    Bishop84
    It's a large solid plate and it can click and creek over bumps. Very slightly and I usually can fix it by loosening it and shifting it.
  11. Nov 8, 2020 at 6:50 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I hope that's it!! We have a tropical storm moving in tonight I'll check that tomorrow
  12. Nov 8, 2020 at 6:52 PM
    soggyBottom
    If you are going let's say 5mph forward and 5mph reverse, is it the same rithem? Maybe record the two and compare?
    My thinking is that 1st and reverse have different gear ratios. You should be able to rule out a lot of they are at the same or different frequencies
  13. Nov 8, 2020 at 7:22 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Sounds the same if forward or reverse, sometimes I can get it changing from reverse to forward, and sometimes I can get it if I stab the brakes
  14. Nov 8, 2020 at 7:49 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    I have the exact same clunking coming from my 2018, at least this is how I would describe it. A loose bolt on the skid plate solved my first clunk, but I haven’t fount the source of this one. I notice it when backing into my driveway or sometimes pulling into a parking spot. I wonder if it’s something with the torque converter, it has a hollow sort of sound like that.
  15. Nov 8, 2020 at 7:54 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Thats it!!!
  16. Nov 8, 2020 at 8:02 PM
    Tacomaryan18
    I’m thinking torque converter because I notice it after shifting into reverse or stopping while pulling into a parking spot. Plus the hollow sound..
  17. Nov 8, 2020 at 8:05 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I hope not, hoping its something simple...
  18. Nov 8, 2020 at 8:12 PM
    Tacomaryan18
    There are many threads about Tacoma driveline clunks related to u-joints ans slip yokes also. For now I’m chalking it up to it being a Tacoma noise. This truck makes a lot more noise than the Tundra I had before it. Oh well, it’s under warranty
  19. Nov 8, 2020 at 8:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe from the Pro lunar rocks knocking around?
    LunarRock_Pro, TRD-ED and b_r_o like this.
  20. Nov 8, 2020 at 8:15 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Only the ones in my head...
