Faint clunking sound 2021 Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Nov 8, 2020.
  1. Nov 8, 2020 at 8:16 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    Take it to the dealership and tell them what happened.. problem solved
    Chako likes this.
  2. Nov 8, 2020 at 10:13 PM
    Chako
    Chako Well-Known Member
    Utah
    1998 TRDOR M/T 2020 TRDOR M/T
    Its most likely something within the driveline, but could be as simple as the leaf springs torqueing and untorqueing.
  3. Nov 9, 2020 at 3:35 AM
    woodlandtaco
    woodlandtaco Well-Known Member
    Connecticut
    2021 Army Green Tacoma TRD Off-Road DCLB
    Is your passenger seat all the way back? I found it to make a clunking sound I mistook for the sound made when your door is slightly ajar and you go over a bump. Brought the seat up a click and seems to have ceased - or at least I haven’t experienced the condition again.
  4. Nov 9, 2020 at 4:06 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Is yours constant and repetitive? Or do you only hear it once and it goes away for the rest of the drive? (Or at least until you change directions such as forward and reverse).
  5. Nov 9, 2020 at 4:41 AM
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    I'd like to hope its something simple that I can deal with, I have the feeling that this is the type of problem that the dealer will have my truck for a week, then say "its normal"...
  6. Nov 9, 2020 at 4:42 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I'll check that.
  7. Nov 9, 2020 at 8:17 AM
    Mace27
    Mace27 Well-Known Member
    18 TRD OR
    Check the chain on the spare tire.
  8. Nov 9, 2020 at 8:45 AM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Mine happens once and goes away Until I change gears/direction.
  9. Nov 9, 2020 at 9:40 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Like this?
    Tacomaryan18 likes this.
  10. Nov 9, 2020 at 9:41 AM
    Tacomaryan18
    That could certainly be my problem. It only clunks once per occasion though
  11. Nov 9, 2020 at 9:45 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    I had this problem a while ago and and the dealer replaced the driveshaft for free. As long if it's easy to replicate by the mechanic I would say take it in and see if they will swap it out. It's covered by the powertrain warranty so if this is the problem you will have a while before you run into any warranty issues.
    Tacomaryan18[QUOTED] likes this.
  12. Nov 9, 2020 at 9:45 AM
    splitbolt
    NW Arkansas
    Per occasion, as in, on first stop after a change in direction?
    Yeah, that's pad slap.
  13. Nov 9, 2020 at 9:47 AM
    Tacomaryan18
    Yes, the first stop after a change in direction. Should I be concerned about pad slap? I can live with the noise
  14. Nov 9, 2020 at 9:54 AM
    splitbolt
    NW Arkansas
    It's normal...no biggie.
  15. Nov 9, 2020 at 10:05 AM
    #35
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    Understood, but i don’t think anyone on this forum is a certified technician who could give you accurate advice. Therefore i would myself would turn my vehicle into the dealership if a problem arose.
  16. Nov 9, 2020 at 10:14 AM
    #36
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    I will once the rain stops!!! Thanks
  17. Nov 9, 2020 at 10:15 AM
    #37
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Don't think its that...
  18. Nov 9, 2020 at 10:25 AM
    #38
    Taco-Blk-Pearl
    Taco-Blk-Pearl Member
    Trd Pro
    I know exactly what it is. It’s the front body mount bushings. This happened to my 2020 TRD Pro and only had about 1k on it. I replaced it with energy suspension bushings. The stock ones really suck. I took it to the dealer twice and they couldn’t figure it out. They’re hopeless. There’s an in depth thread on here about it. After I replaced them, no sound whatsoever. Hope this helps. GL.
  19. Nov 9, 2020 at 6:16 PM
    #39
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    That sucks we're in the middle of a tropical storm, so I'll go through all the suggestions mentioned here, I guess the bushings aren't too bad....
  20. Nov 9, 2020 at 9:25 PM
    #40
    Taco-Blk-Pearl
    Trd Pro
    Check the radiator mount bushings
