Faint clunking sound 2021 Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Nov 8, 2020.
  1. Nov 10, 2020 at 7:25 AM
    #41
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    Several guys over the years have reported that the U-bolts around the rear axle are a bit loose. Which is normal as these to tend to wear in the first couple hundred miles. You may want to climb under there and make sure they are torqued. As I recall they should be around 75Nm.
  2. Nov 10, 2020 at 8:08 AM
    #42
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    Thanks!
  3. Nov 25, 2020 at 2:02 PM
    #43
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Problem found, a front shock boot was loose, and became wedged in the coil spring, dealer replace entire assembly...
    mquibble and Canadian Caber like this.
  4. Nov 25, 2020 at 2:49 PM
    #44
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Thanks for the update. Good luck
  5. Sep 15, 2021 at 8:36 AM
    #45
    danadavenport
    danadavenport Well-Known Member
    2021 SR5 DCLB
    Im having the same sound on my 2021 when turning left in the parking lot. I have an SR5 so we have different shocks. Been at the dealer for 2 days already. Tech says he hears the sound but cant find where its coming from.
  6. Jan 1, 2022 at 12:45 PM
    #46
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I had this when my truck was new. The passenger side front cab mount bolt had loosened off. Tightened it up and no more clunk.
  7. Jan 1, 2022 at 1:10 PM
    #47
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
