Fair price for a '15 TRD Pro w/ blower?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RyanL, Apr 11, 2016.
  1. Apr 13, 2016 at 5:26 PM
    #61
    eon_blue
    Azusa, CA
    haha, exactly. On my daily commute to work, I take it easy and just cruise at 65 in the slow lane to get decent mpg, and I watch everyone in LA fly past me getting to the same place maybe a few minutes faster. Doesn't bug me now though cause I know I could beat most of them if I wanted to :cool:
  2. Apr 13, 2016 at 5:29 PM
    #62
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I've got a pretty slow commute, but there is one section that is two lane, and people like to get in the left turn only lane and cut past the straight lane, then cut you off at the last minute. It's really annoying. So if I can, I smoke em. I used to do it all the time in my STI, by the truck does ok too.
  3. Apr 13, 2016 at 5:39 PM
    #63
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    Well I have to say that the 2.85 pulley is a nice addition and easily doable, but you won't go from 6-8.5 PSI....I haven't seen many people past 7 PSI.
    Regardless, since he just bought the thing, the first thing he needs to do is buy a boost and AFR gauge.
    Then the pulley. I did it during the morning, no specialty tools needed, quite an easy project. Just gotta get a 4 ton 4 inch pulley puller from local store.
  4. Apr 13, 2016 at 5:44 PM
    #64
    cory02taco
    Cory
    Maine
    Just out of curiosity what would you gain from an AFR gauge other than knowing what your mixture is? Without an adjustable ECU isn't it just another pretty face on the dash? Not being critical just genuinely curious.
  5. Apr 13, 2016 at 5:45 PM
    #65
    TacoLand
    TacoLand Well-Known Member
    Congrats on getting the Pro!
    I saw a black Pro last week on I-15 just south of Lehi. To date, in the wild, I've only seen that one and an Inferno Pro in Blanding... (not counting dealership Pro's).
  6. Apr 13, 2016 at 5:52 PM
    #66
    thebottomline
    Pac NW
    11 sport
    You know if you are running lean at wide open throttle, this allows additional upgrades if requires such as fuel pump, 7th injector etc.
    If you are running lean you run the risk of damaged components. Now just the TRD supercharger is fine, but the tune isn't designed to factor in additional upgrades that can lean it out.
    cory02taco[QUOTED] likes this.
  7. Apr 13, 2016 at 6:06 PM
    #67
    Luscious
    Luscious Well-Known Member
    Larry
    Southeastern Wisconsin
    2017 TRD Sport MT, QS DCSB
    Congrats on the Black SC. I have a local car wash that does unlimited deluxe washes and wheel shines for $50/month. Black m/t was my first choice but they couldn't find one, BRM it is...
  8. Apr 13, 2016 at 6:37 PM
    #68
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've seen a few people report 8, the highest was 8.5 (abnormal). 8 is only reached when you really mash on it. Of course this is based on the honor system unless they have gauges with memory. But there are obviously multiple parameters that dictate peak psi such as temperature and altitude.
  9. Apr 13, 2016 at 8:17 PM
    #69
    thebottomline
    Pac NW
    11 sport
    I'm sure there are people even higher than that. I think I meant it as when you are telling someone about a product go with the average or reasonable amount they can expect. typically supercharger does 5.5 PSI and 2.85 adds 1-1.5 PSI. Obviously this is an average though only. More power to you if you are getting 8 PSI, I'm jealous.
  10. Apr 13, 2016 at 9:29 PM
    #70
    ThomasMore66
    Dallas/Fort Worth & Durango
    Now let's start talking about the things you can add...
    And you have to start drinking better alcohol.
    10trdtaco likes this.
  11. Apr 14, 2016 at 5:05 AM
    #71
    cory02taco
    Cory
    Maine
    The air pump relocation on your intake looks a lot better than the volant setup.
  12. Apr 14, 2016 at 5:44 AM
    #72
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    on most official websites. on the double cab selection, theres only trd prerunner and trd prorunner choices?
  13. Apr 14, 2016 at 8:36 AM
    #73
    RyanL
    RyanL [OP] Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    It could've been the guy I just bought this from. I'm usually around Sandy/Draper, so say hi if you see me. What are you driving?
  14. Apr 14, 2016 at 10:36 AM
    #74
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    good luck with it Ryan!
  15. Apr 14, 2016 at 3:41 PM
    #75
    TacoLand
    Driving a white Pro and usually in Salt Lake. I'll keep an eye out for you.
    RyanL[QUOTED][OP] likes this.
  16. Apr 14, 2016 at 9:05 PM
    #76
    ThomasMore66
    Of course it does. That's how I roll. Lol.
  17. Sep 2, 2016 at 8:45 AM
    #77
    RyanL
    Indiana
    Hey @TacoLand was that you I saw coming down 114th last night around 6?
