Fake alarm flashing light, sub 20$, about dodges three times
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IronPeak, Apr 20, 2016.
  1. Apr 20, 2016 at 7:37 AM
    IronPeak
    IronPeak [OP] PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    41tqAPmJvuL._SY90_.jpg 20160420_074521.jpg 20160419_224117.jpg 20160420_074521.jpg
    After spending couple hours yesterday figuring out my 12v socket fuse was indeed live all the time ( duh on my part)
    >>>> thanks go to @nd4spdbh <<<<
    I am ready to get started on my fake alarm led light. Trying keep it nice and simple working w just my dash area. Hopefully it prevents a smash and grab. I where i park on the weekends the ground is littered with tempered glass...
    So here's the gear I've got so far, just need to assemble. Flashing relay, led light, spdt relay , 2 fuse taps. the adjustable Flashing relay has some funny chinglish on it, check it out. About dodges three times? I mean seriously, still trying figure out what they were trying to convey w that...Well, It works, tested it, hope it doesnt burn my truck down haha... uh, ha ha , uh.... it adjusts perfectly, not like a regular turn signal flashing relay from auto part store... more like from strobe (no good for me) to off for few seconds then a 1/2 second flash., just like an alarm system.
    Two fuse taps will supply power constant (one from the 12v socket fuse which is live all the time) the other from a fuse that turns off with the truck. this will close the normally open relay when the truck is turned off, thus closing the flashing relay, and then ta da the led light does its thing...... total price? Sub 15$ ...edit, the led recently went up in price to 7 bux...I'm damn sure there was an easier way to do this but with my limited knowledge and the help of TW members this is what I came up with.... p.s, the Lil pic is the reg relay... if anyone can see any steps/ parts I can eliminate, (like do i really need two fuse taps?) please let me know, thanks
  2. Apr 20, 2016 at 8:07 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  3. Apr 20, 2016 at 8:14 AM
    IronPeak
    AuggieX
    Back to Back
    I checked these out, the flash rate didn't work for me, some were a strobe, some like a turn signal also those are too bright, didn't want to mess with inserting a diode.... my reg led was 1.50 free ship Amazon prime ..edit looked just now they are 7 bucks....the adjustable flashing relay was like 9$., flash rate is few seconds off, then a 1/2 sec flash. Similar to an alarm.. also need to supply power when truck is off , and not when truck is on.. but damn those are cheap....
  4. Apr 20, 2016 at 8:20 AM
    IronPeak
    AuggieX
    Back to Back
    Also the 1.50 led (edit looked they are like 7$now..)I got is on a threaded stem with a nut, drill 1/4" hole, tighten nut, flushmount
  5. Apr 20, 2016 at 8:48 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Can you provide the Amazon links to the items you have listed above?
    IronPeak[QUOTED][OP] likes this.
  6. Apr 20, 2016 at 8:53 AM
    IronPeak
    AuggieX
    Back to Back
  7. Apr 20, 2016 at 9:00 AM
    IronPeak
    AuggieX
    Back to Back
    To wire the "about dodges three times" adjustable relay, it's 12v to the + post, ground the - post, positive wire to led from " L" post, be sure to ground other wire from led pigtail... adjust away to your liking....
  8. Apr 20, 2016 at 9:06 AM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    me, I'd probably use a 'ne555' timer chip, and a couple resistors and capacitors tuned to generate the appropriate duty cycle, generic red LED, wire it to always-on power, and ignition-on-power wired to disable it. this all would fit on a tiny breadboard less than 1" square.
    of course, my buddy would do it with a 'PIC' micro CPU chip, which would draw microamps (above ne555 analog circuit would likely draw around 25 milliamps).
    I'd want about a 1/4 second blink every 4 or 5 seconds, I think that would be close to the rate of the typical bungler annoyer.
    deeve and IronPeak[OP] like this.
  9. Apr 20, 2016 at 9:46 AM
    deeve
    deeve Well-Known Member
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    IronPeak[OP] likes this.
  10. Apr 20, 2016 at 10:10 AM
    IronPeak
    AuggieX
    Back to Back
    Video confirms what I already knew...haha...that I was over thinking this project with very little electrical experience... had i found that product I would likely have bought it instead of my silly build... would still use fuse taps rather than soldering into my ignition wire. I found the device in the vid for 24$ , add fuse taps, few more bucks....
    One thing of value that I did get out of this is a working knowledge of how to configure different relays for different purposes... I have used them in the past for accessory lamps on my ARB bumper but it was a plug and play harness, just mounted the relay in the engine compartment , had no idea what 87a, 30, etc was for, etc....
    I now have confidence to make, say, my own harness for a light bar or whatever, using premium parts, proper type of automotive wire, rather then buying a pre made Chinese one, that may have spotty solders, using the absolute minimum gauge wire, etc (uh, all the parts in my build are cheap Chinese, haha!!!! But at least I know the solders are good, shrink wrap etc...)
  11. Apr 20, 2016 at 10:20 AM
    deeve
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    I would rather go through the process you did than just buy an off the shelf part. Like you said, you learn so much through working through your own solution.:thumbsup:
  12. Apr 20, 2016 at 11:21 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Seasoned car thieves don't worry about flashing alarm lights. There fast. It's a skill of the trade.
    Simon's Mom and IronPeak[OP] like this.
  13. Apr 20, 2016 at 11:45 AM
    IronPeak
    AuggieX
    Back to Back
    And thats why i didnt purchase an alarm...Ya the pros can steal any car , alarm or not. The intention of this is to discourage smash and grab scumbags, where I park on the weekends the ground is littered with tempered glass. I figure they will be at least SLIGHTLY more likely to smash a window in the car next to mine, without the flashing light, if they think a loud alarm is going to go off.
    That said, I agree, car alarms are useless, and in the past when I had one it was annoying, going off when a Harley went past it, causing electrical problems etc. I wouldn't advise anyone to buy an alarm. Waste of money and won't stop a pro for more than 3 seconds. People don't pay attention to alarms anymore. People I know don't even bother looking out their window if one goes off, it's just background noise like a bus going by or a bum screaming to god at the top of his lungs at 3am... people just don't give a sh#t in urban areas....
    Mattynokes likes this.
  14. Apr 20, 2016 at 11:55 AM
    IronPeak
    AuggieX
    Back to Back
  15. Apr 20, 2016 at 11:57 AM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    factory alarms with immobilizers integrated into the ECM are pretty hard to bypass in the few seconds a car thief wants to spend.
  16. Apr 20, 2016 at 12:04 PM
    IronPeak
    AuggieX
    Back to Back
    Yes modern cars are less likely to be stolen immobilizers are built in with or without a factory or aftermarket alarm
    In san francisco, there were 7000 car thefts last year, but I'm assuming they are older sedans
    2012 report, released in August 2013, NICB cautioned that newer models of a nameplate may hardly be stolen at all; their nameplates may appear on the top-10 most-stolen list each year because older models are still very popular with thieves. In 2012, for example, only 393 model-year 2012 Civics were among that 47,037 total.
    The vast majority of car thefts are for the parts that can be harvested from it, making older import sedans the most stolen vehicles, as they are easily stolen by someone without any "skills" at all, using a shave key or popping the steering column and hotwiring it
    Of course, if the pros have a flatbed
    / tow truck nothing is gonna stop that...
  17. Apr 20, 2016 at 1:16 PM
    spitdog
    I agree, I had an alarm in my last Tacoma and it drove me nuts. After the 1st week I disarmed it.
  18. Apr 20, 2016 at 1:49 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    why
    when 50 cent 12 volt self-contained miniature LED's already exist, with various blink timings
    you don't need all that extra crap. the only hard part is finding the 'hot when ignition off ' wire
  19. Apr 20, 2016 at 2:10 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    This is great :thumbsup:
  20. Apr 20, 2016 at 2:28 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    the only way you'll get 'hot with ignition off' is to create it yourself with logic or a relay.
    those off the shelf blinking LEDs linked previously blink at 1-2Hz, with a 50% duty cycle. 2Hz would be 0.25 seconds off, 0.25 seconds on, repeat. thats way too fast.
    speaking of alarms. my 2008 Taco has a 'toyota alarm', there's a remote control, presumably an engine imobilizer, a red LED in the dash (between the clutch start cancel, and the differential lock buttons)... when I lock and unlock the car with the remote, the parking lights blink a couple times, but there's no "BRAP! BRAP!" or whatever that too many alarmed cars I've had in the past had... I left the drivers window down, remote locked the car, then opened it by reaching in, no BRAAAP BRAAAP. does this mean my alarm has been disabled?
