Falcon Shocks for Tacoma by TeraFlex - new suspension options for 2016+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tow-coma, Feb 1, 2018.
  1. Feb 1, 2018 at 3:03 PM
    tow-coma
    tow-coma [OP] Well-Known Member
    This came up on my Facebook feed today as an advertisement.
    Some quick info from what I've read:
    - Internal droop spring instead of topping cone or valving design
    - Bump stops "to reduce bottoming" with stock coil
    - 2.25 inch bodies
    - 0.75 inch shaft
    - piggy back reservoirs on rears
    - 3 retainer rings on front bodies
    - Factory or other coils are needed "Largest shock body that will fit w/out modifications"
    - Factory service and rebuild available
    - 3 year warranty
    - 1349.99
    - their description of "digressive linear" valving sounds more like progressive damping...
    These are already on Back Order..... are they very popular or have they not released them yet ? ? ?
    https://www.falconshocks.com/toyota-tacoma
    The Toyota Tacoma Falcon Sport Shock Absorber System is engineered to deliver increased stability and control as well as improved ride quality and comfort both on and off-road. These compact and affordable shocks are ideal for daily driven vehicles.
    ZRT - Zone Rate Tuning
    Zone Rate Tuning (ZRT) manipulates the factory linear-rate spring tuning to produce three distinct performance zones with a more exaggerated spring curve to tackle various driving conditions.
    An internal negative-rate spring offsets the factory spring’s preload while in the Extension Zone. This eliminates top out clunk and shock stress at full extension, while softening tire landing and reducing body roll on impact during aggressive driving.
    The factory spring rate is unaffected in Drive Zone for a comfortable and controlled ride. A provided progressive microcellular bump stop effectively retunes the spring rate while in Compression Zone to reduce bottoming and body roll during aggressive driving.
    VOD - Volume Optimized Damping
    Traditional velocity sensitive shock absorbers react quickly during low speed driving causing excessive “head toss” on rough terrain – or even driveways. Conventional damping then firms up during faster speeds resulting in a jarring ride.
    Falcon’s proprietary Volume Optimized Damping (VOD) features a digressive linear valve that produces quicker ramp up for increased damping volume, which improves vehicle feedback and control during low-speed driving. VOD also improves the shock absorber’s ability to reduce bottoming out at full compression during faster speeds or over uneven terrain.
    FITS:
    • 2016+ Toyota Tacoma
    INCLUDES:
    • Two (2) monotube front shock absorbers
    • Two (2) piggyback rear shock absorbers
    • Front & rear progressive microcellular bump foam bump stops
    • Billet coil spring carrier
    • Injection molded squeak-free spring isolator
    • Rear bump stop cups
    • Rear Roost Guards
    • All necessary hardware
    FEATURES & BENEFITS:
    • Application-specific pickup shock absorbers w/ race-inspired performance
    • Front shock features multiple snap ring grooves to level out front end
    • Snap ring grooves maintain set ride height (instructions laser etched on shock body)
    • Dramatic improvement in on-road comfort & off-road performance
    • Increases vehicle stability
    • Improved dynamic roll control & low speed damping
    • All testing done on E-rated tires (worst possible ride)
    • 2.25” shock body provides optimal performance
    • Largest shock body that will fit w/out modifications
    • Optimized fitment for clearance during full suspension travel
    • 6061-T6 aluminum alloy shock body resists wear & protects internal components while providing superior heat dissipation
    • Smooth honed internal shock body surface for long-term performance
    • 3/4” shaft to prevent shaft buckling
    • Induction hardened chrome plated shaft resists rock damage & corrosion
    • Hard anodized piston
    • Zone Rate Tuning (ZRT) retunes the factory spring in the Extension, Drive & Compression zones
    • Negative spring inside shock body eliminates top out clunk, softens tire landing, & reduces body roll & stress on shock
    • Application-specific tuned bump stop reduces bottoming out & body roll
    • OGS – the oil/gas separator prevents cavitation
    • Digressive linear piston
    • 1-piece Teflon bronze piston wear band w/ O-ring
    • High-quality spherical bushings (when applicable)
    • Zerk fittings to lube bushing (when applicable)
    • Red Line full synthetic shock oil with high viscosity index of 519 for consistent performance across all temperatures & reduced shock fade
    • Synthetic formula also contains special anti-wear & lubricity agents for excellent thermal stability
    • 1,000-hour salt spray corrosion resistance test on all hardware
    • Serviceable & rebuildable (factory serviced)
    • Built in-house at the TeraFlex Falcon Shock Division
    • Patent pending design
    • 3-year warranty
    NOTES:
    • Never exceed factory tow/haul ratings.
    INSTALL TIME: 3.5 Hours
  2. Feb 1, 2018 at 4:02 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    My guess not released yet but I’m intrigued. They make awesome stuff for Jeep.
    DustStorm4x4 and ChadsPride like this.
  3. Feb 1, 2018 at 4:20 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Sub'd. hope this does not become a manufacture in ability to deliver item like Nitro 4.88's. Yah the vendors have them all day long, if you want to pay a marked up price.
  4. Feb 1, 2018 at 4:20 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Whatever you do, don't let your brother install the sticker.
    Armedine, Malinosan, allenn and 94 others like this.
  5. Feb 1, 2018 at 4:23 PM
    here4cake
    here4cake Well-Known Member
    The 3 year warranty is intriguing.
  6. Feb 1, 2018 at 6:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Same with OME highest end dampers
    Juforrest likes this.
  7. Feb 2, 2018 at 8:08 AM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Sub'd. Although I like another lift option, I'm getting so confused on which one to go with lol.
  8. Feb 2, 2018 at 8:11 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    sub'd I wonder why no option for the 2nd gen.
  9. Feb 2, 2018 at 8:20 AM
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    You can run them on a 2nd gen no problem. It's just the way they decided to market them.
    Brice, Gunshot-6A and 12TRDTacoma like this.
  10. Feb 2, 2018 at 8:54 AM
    TacoTRD78
    Stuart,fl
    I would assume so considering other suspension manufactures make compatible components amongst the 2nd and 3rd gens.
    i_cappi[QUOTED] likes this.
  11. Feb 2, 2018 at 9:12 AM
    RAV3N
    RAV3N Well-Known Member
    24 TRD O/R
    Sub’d
  12. Feb 8, 2018 at 6:50 PM
    Off Road Ned
    Off Road Ned Member
    Ned
    2017 Black Tacoma TRD Off Road AT
    Stock
    I got the same feed on facebook too, I asked if they are extended travel but have yet to get a reply. They sound interesting.
  13. Feb 8, 2018 at 7:27 PM
    Macadamia
    Macadamia Member
    2017 TRD Off-road
    Do these lift up the truck any or are they just different type of susp
  14. Feb 8, 2018 at 7:30 PM
    Off Road Ned
    Off Road Ned Member
    Ned
    Stock
    It has adjustment, rings so yes it could, in the front only
  15. Feb 13, 2018 at 6:01 PM
    AZTaco77
    AZTaco77 Active Member
    Arizona
    2018 Cement TRD Offroad
    I have it on good authority the Tacoma parts will become available in March! I have a full set on order with Doetsch Off-Road here in Arizona. They recently put a 2.5" leveling kit on my truck and I was admiring some of their Wranglers with the Falcon's and thinking about how cool it'd be to have that setup on my Taco. I am building my first Taco after about 6 personal Wrangler builds plus helping a number of friends build their Wranglers and I have experienced TeraFlex from spacer lifts to full blown setups. The Falcon setup on the Wrangler is INCREDIBLE! I cannot wait to see how these perform on the Taco!
    ......Now I need to order wheels and tires to round out these upgrades
  16. Feb 13, 2018 at 6:03 PM
    Off Road Ned
    Off Road Ned Member
    Ned
    Stock
    how much more travel over stock are they saying these are?
  17. Feb 13, 2018 at 8:09 PM
    tow-coma
    I assume none
  18. Feb 13, 2018 at 8:12 PM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
  19. Feb 13, 2018 at 8:13 PM
    splitbolt
    NW Arkansas
    Anxious to hear your review.
    su.b.rat and AZTaco77[QUOTED] like this.
  20. Feb 13, 2018 at 9:19 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Subbed for info
