Falken wild peak vs BFG AT K02. Which one and why?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Sep 14, 2021.
  1. Sep 14, 2021 at 6:03 PM
    #61
    philth
    philth .
    The sidewalls are almost identical.
    0D810AA6-324B-42CC-A593-10A43181B3F1.jpg 1AB56F75-E54F-418B-B440-2B5DAF0C3ECF.jpg
    Again, I’ve ran K02s for what is probably hundreds and hundreds of thousands of kms across many different vehicles for work and pleasure. I’ve had ZERO issues with the tires themselves. From all over the US to up here, all across Canada - in ALL weather in all sorts of terrain. I’ve had a few punctures and gotten stuck a few times - but these were MY ERROR, usually forcing vehicles into area above their (and the tires) limitations.
    The K02s are also widely available - you’ll find them in the most rural shops around North America (maybe even the world?) if you’re stuck somewhere remote and in need of rubber.
    All that to say Driver > Rubber.
    Unless you’re a professional driver of some sort, but that’s an extremely rare exception to the rule.
    IrishRed, omegaman2 and mikesixtysix like this.
  2. Sep 14, 2021 at 6:49 PM
    #62
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    275/70/17 with TRD Lift. 2" front 1" back
    No rub at all
  3. Sep 14, 2021 at 7:05 PM
    #63
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    In that case OP should get ST MAxx's and look down on all others.
  4. Sep 14, 2021 at 7:14 PM
    #64
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Anyone have experience with Wildpeak tires in Nevada? Specifically northern Nevada rocky dirt trails and Sierra snow?
  5. Sep 14, 2021 at 7:16 PM
    #65
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Just got the Wildpeaks in 275/70/17 about 6 months ago, no lift, no complaints. Took them out for a pretty good test on Sunday. Mud holes that bottomed out the struts and I forgot to take my hitch out so I was carving small ditches behind me. They are surprisingly quiet to me. Ran BFG’s on several vehicles and they were good tires, no complaints. I would buy either again but would probably go Wildpeaks because of the price difference.
    philth, Fedup13, DavesTaco68 and 2 others like this.
  6. Sep 14, 2021 at 8:20 PM
    #66
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    Nah the KO2s have a gross looking sidewall that almost blends into the tire IMO whereas the wildpeaks look more "wild" like you can spot it a mile away
    Totally just my subjective view on it
    philth[QUOTED] and Lt. Dangle like this.
  7. Sep 14, 2021 at 8:26 PM
    #67
    Integerdy
    Eric
    So-Lame, Oregon
    You stuffed 275s in there with no rub? Wild lol
    I was so scared that mine would rub with a 2" lift. I still feel like it will sometimes but clearly it hasn't and I've driven it a fair amount.
  8. Sep 14, 2021 at 8:27 PM
    #68
    Rainman443
    A Big Island
    2021 TRD OR
    OP, if you're looking for the best performing tire, look into the Nitto Trail/Ridge Grapps. Would've got them if I cared about performance (and not sidewall appearance). trail grapplers seem to be the most frequently preferred tire amongst the pro rock crawlers but if a mud terrain isn't for you, the ridge grappler is the closest thing to it
    Tacomod likes this.
  9. Sep 14, 2021 at 8:28 PM
    #69
    Rainman443
    A Big Island
    2021 TRD OR
    There's a video showing this but a suspension lift won't change your rubbing because it'll compress to the same spot. Off the street, If it works with a lift, it'll work without.
  10. Sep 14, 2021 at 8:32 PM
    #70
    kauaihunter
    Jay
    They do rub a little, mostly on a downhill turn, it just touches the plastic inner fender liner towards the rear of the truck. No metal contact at all.You can see the clean spot here. I think the offset on the 4Runner wheels may help a little. Not sure. Regular daily driving, no rubbing.
    chuam likes this.
  11. Sep 14, 2021 at 8:33 PM
    #71
    PNWlongbed
    PNWlongbed Well-Known Member
    Alexander
    2007 Tacoma Access Cab
    get a caster allignment and a cmc and youll be perfecr!
  12. Sep 14, 2021 at 8:34 PM
    #72
    PNWlongbed
    Alexander
    The bigger tires fit with just a little work
  13. Sep 14, 2021 at 8:36 PM
    #73
    Rainman443
    A Big Island
    2021 TRD OR
    can't tell for sure but if that's the front, trim it or you can have an alignment tech pull back your caster if you got space in the back
  14. Sep 14, 2021 at 8:41 PM
    #74
    Lt. Dangle
    Ohio
    Looks like rear side driver judging by the wire loom there.
    Heat gun and press it back man.
  15. Sep 14, 2021 at 8:48 PM
    #75
    kauaihunter
    Jay
    It is the rear but normal daily driving it doesn’t touch at all. Steep downgrades and a full lock on the steering is where it makes contact most of the time. Or if I hit a swale or steep grade change too quick while turning it’ll touch but I have to almost be driving too fast to make it happen. When I first had them installed I did all kinds of stuff to see if and where it would touch.
    That pic was taken on Sunday where the suspension was maxed out. If I wash the truck, you can’t even tell where it touches, so far anyway. In time I’m sure it’ll eat the liner if I don’t push it back.
    chuam likes this.
  16. Sep 14, 2021 at 9:30 PM
    #76
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I have Falkens on my Wrangler and now my Tacoma. Both sets had one tire that was difficult to balance (two different shops). I'll try something else next time.
  17. Sep 14, 2021 at 10:21 PM
    #77
    Rainman443
    A Big Island
    2021 TRD OR
    We have the same setup, except I have 2" lift. Have yet to take it off road and flex, but I rub on my mudflaps at half turn to the left, hoping some RokBlokz flaps will fix it because I love having flaps (keeps the body spotless). Caster also helps since I was only able to get 0.2 on the left and 0.9 on the right (doesnt rub ever on the right)
    kauaihunter[QUOTED] likes this.
  18. Sep 14, 2021 at 10:29 PM
    #78
    Aptaco272
    Aptaco272 TRASH PANDA
    Unspecified
    L5P Duramax
    Some
    I researched quite a bit. Ended up with 5 wildpeak at3s. So far I have zero complaints.
    ghostleaf likes this.
  19. Sep 14, 2021 at 10:38 PM
    #79
    106
    106 Well-Known Member
    '21 DCLB TRD Off Road - Army Green
    ST Maxx's. For no reason other than I bought a set yesterday and I would like to validate my purchase.
  20. Sep 14, 2021 at 10:49 PM
    #80
    Maximum Average
    Maximum Average Well-Known Member
    Curt
    Quicksand TRD off road
    when the falken vs ko2 question arises, I always recommend Duratracs. It's a fantastic tire in rain or snow. it's great off road. it's great on road. the treads are very deep.
    the work phenomenally and look great while doing it.
    kauaihunter likes this.
