Falken Wildpeak A/T4W on 4th Gen Tacoma's
Discussion in '4th Gen. Tacomas (2024+)' started by Nduke0070, Apr 8, 2025.
  1. Apr 10, 2025 at 3:28 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    I think the KO3 addresses those issues.
    JB_TN likes this.
  2. Apr 13, 2025 at 2:31 PM
    Pappy Jon
    Pappy Jon Well-Known Member
    RZN60LV
    3RZ
    I'm running those tires in load range C. But, I also have a camper canopy and heavy rear bumper. If you don't have the load, you can run SL.
  3. Apr 13, 2025 at 2:53 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I personally wouldnt waste funds on BFG's....
    Some folks love them, but from my research, hard to keep round, & to me, not worth the cost.....
  4. Apr 13, 2025 at 3:04 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I ran them on my 3rd gen 2017. I thought I would give the KO3 a try. I’ll give you my impressions in 5 years.
    thefinalstraw likes this.
  5. Apr 13, 2025 at 3:24 PM
    Taco Ji
    New Jersey
    I just ordered the wildpeak AT4W SL.
    slater[QUOTED] likes this.
  6. Apr 13, 2025 at 4:41 PM
    slater
    San Diego
    Cant go wrong, good pick....
    Majority of guys in the industry #1 pick would be the Toyo Open Country ATIII , but sidewall isnt very aesthetically appealing......
    My chick had a set on her ford ranger & NEVER once rotated them & they wore evenly until they were racing slicks, unheard of...
    But between a Falken & a BFG, Falken all day....
    Nicholijack likes this.
  7. Jun 11, 2025 at 4:42 PM
    Nicholijack
    Nicholijack Well-Known Member
    Nicholi
    2024 Tacoma 6MT
    yup. this advice isn’t given as much as it should be. unless you’re pulling at max tow capacity a lot- most people are fine with SL rated tires. i have hundreds of miles on forest service roads and my SL Coopers do great.
    rybern likes this.
  8. Jun 11, 2025 at 6:53 PM
    cgrigsby79
    cgrigsby79 Member
    2025 Tacoma SR5 4wd
    I bought the Falken A/T4W 285/70/17 SLs and couldn't be happier. Awesome traction in the rain, super quiet, look great, no rub on a stock SR5, and no discernible drop in mpg. Plan to swap them over to some wider SCS or RRW wheels at some point.
  9. Jun 11, 2025 at 7:05 PM
    alwzdfnt
    alwzdfnt Well-Known Member
    2025 TRD Sport
    285/70/17 here IMG_1694.jpg
  10. Jun 11, 2025 at 7:33 PM
    JR_Roams
    JR_Roams Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    The weight difference between C and E rating is negligible and most of the time are the same, change my mind. Falken wildpeak a/t4w 255/85 r16 C rated weighs 58.4 lbs. A tire that is basically the same diameter MUCH wider and E rated BFG KO2 285/75 R16 E rated weighs 58.6 lbs.
  11. Jun 12, 2025 at 6:40 AM
    Eesh
    Eesh Well-Known Member
    Canada
    2025 Tacoma Limited
    I have 265 70R18s SL on my 2025 Limited. And I love them. ZERO rubbing
  12. Jun 12, 2025 at 10:34 AM
    Taco Ji
    New Jersey
    If you get zero offset then you will rub slightly. :)
  13. Jun 13, 2025 at 2:00 AM
    Droid
    Droid Well-Known Member
    22 Pro 6MT #FFFFFF
    I think the AT4W is an excellent tire but is quite heavy in LT sizes. Have a set of C-load "Duraspec"-sidewall LT315/70R17 on another vehicle and they are 78lb a piece. Massively deep tread while being the quietest A/T I've ever (not) heard. Great in snow, snow on ice, crazy rain, and dry. Also have a set of SL in P265/75R16 on an old truck, they have HALF the tread of the C-load version but ride great. Can't tell you how those work in snow/rain as that vehicle is not allowed to outside in such conditions. :D
    I'm looking for 285/75R17 for the Tacoma (whenever it gets here) but am not even considering the AT4W. Too heavy even in load range C in that size in my opinion (68lb, 9lb more than the Toyo AT3). I'm going up from 36lb stock tires so adding +23lb/corner even with the Toyos..it'd be +32lb/corner with the AT4Ws. Would definitely want them but for the weight.
    When shopping for AT4Ws, pay close attention to the sidewall stamp listed on each size here: https://www.falkentire.com/wildpeak/at4w
    The "Duraspec" load range C tires have a very stout sidewall. The "standard" sidewall load range C tires are more akin to an SL I think. As an example, look at the difference in weight between the 275/70R17 and 285/70R17 in load range C. The 275 has a "standard" sidewall and the 285 has a "Duraspec". Both have 18/32 of tread depth, but the 275 weighs 7.3 lb less. My understanding (and I could be wrong) is the Duraspec are unusually tough (and heavy) C-load tires that offer the protection of E-load with a better ride (but still with all the weight).
    Weight is third-to-last column, 58.1 vs 65.4:
    Canadian Caber likes this.
