Falken Wildpeak AT/3 tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeeptec, Aug 13, 2018.
  1. Dec 21, 2020 at 11:34 AM
    #521
    Tzell11
    Tzell11 Well-Known Member
    Thomas
    Fort Worth, TX
    ‘18 MGM TRD Sport
    Thanks I appreciate it! I know, but I prefer to have more of a gap between the wheel and fender for my own personal aesthetic preferences :D
    SilverSky195 and Norsk[QUOTED] like this.
  2. Dec 21, 2020 at 11:39 AM
    #522
    Norsk
    Norsk Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
    Gotcha! I like meaty tires!
    Tzell11[QUOTED] likes this.
  3. Dec 21, 2020 at 12:18 PM
    #523
    Tzell11
    Thomas
    Fort Worth, TX
    ‘18 MGM TRD Sport
    You and me both! Im just trying to keep it all proportional, probably go bigger when I lift it later on down the line. Your truck looks great by the way! Killer stance
  4. Dec 27, 2020 at 11:12 PM
    #524
    LB9
    LB9 Well-Known Member
    Louie
    2007 Toyota Tacoma DCSB TRD OffRoad PreRunner - OME 884's, 5100's, HS AAL, SCS SR8
    Just got 265/75 16s installed on my 07 along with SCS SR8 wheels, Bilstein 5100's, OME 884 and HS AAL. What a difference from stock.
    lo2hi, ghostleaf and PandaPandaPanda like this.
  5. Jan 3, 2021 at 2:36 PM
    #525
    Odysseus216
    Odysseus216 Well-Known Member
    2017 Tacoma TRD Off-Road DCSB (Quicksand)
    how does your truck drive with 265/75s? I'm thinking about upgrading to 265/75. Do you think it's necessary to regear at all?
  6. Jan 3, 2021 at 2:55 PM
    #526
    lorsteez
    lorsteez P-Town Resident (415|707)
    Northern CA
    2019 DCLB OR- Cement
    Fox 2.0 Coilovers|Fox 2.0 Rear Reservoir Shocks | Icon 1.5 AAL w/Overload | Method 305 NV 16 X 8 | Falken Wildpeaks 267/76/16 | | Diode Dynamics SS3 LED Fogs | SR Grille Surround
    265/75/16’s on my DCLB. I don’t feel any need for a re-gear especially after the recent TSB update.
  7. Jan 3, 2021 at 3:57 PM
    #527
    Odysseus216
    Have you had any rubbing issues at all? I still have stock suspension, I'm not sure if I'll rub with 265/75s.
  8. Jan 3, 2021 at 4:00 PM
    #528
    lorsteez
    Northern CA
    No but I’m on Fox 2.0’s with a 2.25 inch lift.
  9. Jan 3, 2021 at 5:34 PM
    #529
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  10. Jan 3, 2021 at 5:39 PM
    #530
    lorsteez
    Northern CA
    Bertw192[QUOTED] likes this.
  11. Jan 3, 2021 at 6:07 PM
    #531
    barnes828
    barnes828 Well-Known Member
    Nathan
    Vancouver, Wa
    21’ DCLB OR WHITE
    Stock truck, 265/70/17 wildpeaks on TRD PRO wheels, REK GEN mudflaps, and DD SS3 Max’s. My tires rub in reverse full lock on the fender liner just above the flap with some heat and bending it would clear it up.
    CavalryTRD and SouthernFried like this.
  12. Jan 3, 2021 at 6:36 PM
    #532
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    I have the exact same set up and I'm pretty sure it's rubbing on the spacer bolt on the rekgens. I removed them and had no rubbing
    CavalryTRD and jondoeski like this.
  13. Jan 4, 2021 at 4:04 PM
    #533
    Jamesr913
    Jamesr913 Well-Known Member
    2019 Cement Tacoma offroad
    I have 265/75/16s on a stock suspension with no rubbing.
  14. Jan 4, 2021 at 7:45 PM
    #534
    CubanSammichPt2
    CubanSammichPt2 Well-Known Member
    2020 TRDOR Tacoma
    Stock
    I actually think it drives better tbh. I haven’t re geared or anything. Also I didn’t pick e-rated tires. So tire weight is still relatively low. So that probably helps. I live in Oregon and ride on a lot of rocky trails(nothing crawly, just lots of smaller sharp rocks). Haven’t had any punctures. Don’t really see the need for e rated. I just have the SL
    ghostleaf likes this.
  15. Jan 4, 2021 at 8:44 PM
    #535
    Carhanu
    Carhanu Well-Known Member
    Michael
    2020 Red Tacoma TRD Off-Road
    Those Falkens are certainly impressive tires and definitely something to consider if you live in a snowy region. Personally, I am leaning toward the Goodyear Wrangler UltraTerrains (aka Ghetto Duratracs). They have a deeper tread, lighter weight than the Falkens, and just look beefier all around. I'm sure the Falkens are better in snow but I live in Southern California so i barely ever drive in the snow.
  16. Mar 16, 2021 at 9:45 AM
    #536
    AdventureTaco
    AdventureTaco Active Member
    Tom
    Virgini Beach, VA
    2019 Tacoma TRD Off-Road
    Just put on the Wildpeaks. I like the look, but I’ve noticed an immediate and very noticeable change in handling. The steering feels dead and it’s slow to turn. Has anybody else experienced this? Same size 265/70/16 SLs49296B92-8CCD-49CF-940D-8A459AB88ED3.jpg
  17. Mar 16, 2021 at 11:00 AM
    #537
    AdventureTaco
    Tom
    Virgini Beach, VA
    I just put these on myself and noticed a significant change in the steering. Feels muted. Did you notice this?
  18. Mar 16, 2021 at 1:40 PM
    #538
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Well, its about the same size tire so unless they messed something up changing them it shouldn't be like that
  19. Mar 27, 2021 at 10:50 AM
    #539
    jn2399
    jn2399 Well-Known Member
    Jon
    2018 TRD Sport 4x4
    Pro Wheels.
    For guys that got these in 275/70/17 or 265/70/17. I noticed that these tires are a little on the heavy side according to the websites. Do you guys think a re-gear would be necessary to accommodate this weight? or Have you guys been fine with these tires? I am considering pulling the trigger on this for my next tire and want to be sure that I'm making the right decision. Thanks!
  20. Mar 27, 2021 at 7:27 PM
    #540
    ryanvar42
    None
    Not for that tiny tire size. If anything and I mean IF you wanted to adjust for the size then get a tune
