Falken Wildpeak AT/3 tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeeptec, Aug 13, 2018.
  1. Jun 30, 2021 at 11:22 AM
    #561
    onesixonetwo
    onesixonetwo Well-Known Member
    Interested as well. Normally they say 265/70/17 is the largest you can go with no rub.
  2. Jun 30, 2021 at 3:06 PM
    #562
    MinkusLinkus
    MinkusLinkus Member
    Seattle, WA
    2021 Cement TRD Off-Road
    I haven't had any issues with rubbing but have only had this set up for 24-hrs. Turning the wheels lock-to-lock I don't get any rubbing at all, so don't expect any. At least on asphalt. The closest it gets is the backside with the mud flaps. Photos below. Again, this is with the OEM lift kit which is a 2" front lift.
  3. Jul 1, 2021 at 4:28 PM
    #563
    bliso249
    bliso249 Member
    Ben
    Pittsburgh, PA
    2020 MGM TRD OR DCSB
    Just got back from the local tire shop! Switched out my stock wranglers with 22k miles and terrible wear patterns for Wildpeak SL 265/75/16. Love the look! They look even better in person. Gas mileage was the same as I was getting before from what I can tell approx 20 mpg. I made sure they put the raised lettering side out. No rub on my OEM mudflaps so far. Stoked!
    Accidentally posted this on the Toyo Open Country page first lol. I’m happy with my choice!
    [​IMG][​IMG][​IMG]
  4. Jul 1, 2021 at 6:17 PM
    #564
    Flyersfan36
    Flyersfan36 Well-Known Member
    I want to get these when my new wheels get in. Not sure what size I'll be able to fit with no rubbing and stock suspension. The wheels are -12 offset so I'm guessing that will make a difference.
  5. Jul 2, 2021 at 7:18 AM
    #565
    The Toronto Taco
    The Toronto Taco Member
    Jake
    Toronto, Canada
    2021 Tacoma TRD Sport Premium
    TRD Wheels 265/75/R16 Falken Wildpeak Tires TRD Pro Front Grill w/Amber Lighting
    I have a similar setup and I removed the front flaps to give it a bit of extra room... it was a bit too close for comfort :facepalm:
  6. Jul 6, 2021 at 8:51 PM
    #566
    MinkusLinkus
    MinkusLinkus Member
    Seattle, WA
    Over the weekend, I did notice some rubbing with the middle part of the front flaps. Looks like they do rub slightly midway between straight and full turn. Noticeable when backing up but not so much going forward.
  7. Jul 7, 2021 at 5:58 AM
    #567
    The Toronto Taco
    Jake
    Toronto, Canada
    You could try trimming the material back a bit but I don’t really find the front flaps do much anyway… my truck is under coated so I’m not too concerned about rocks getting kicked up and hit those components. My biggest concern was with how tight it was an if I get snow packed in there or heavy mud it might rip something off or keep the wheel from being able to turn :frusty:
    MinkusLinkus[QUOTED] likes this.
  8. Jul 7, 2021 at 12:22 PM
    #568
    MinkusLinkus
    MinkusLinkus Member
    Seattle, WA
    Makes sense. I'll have to think about that. I took the flap off to get a closer look at it and there doesn't seem to be much to trim. Might have to drive without the flap on and see whether that's better. But you're point about wheels being caked is well taken.
  9. Jul 7, 2021 at 3:19 PM
    #569
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    This is where my 275’s rub on my stock SR, on a steep downhill, fully locked turn.
    Note that I have 2020 4Runner wheels mounted. For me, doesn’t seem like it’s affected the truck much at all.
  10. Jul 7, 2021 at 3:25 PM
    #570
    kauaihunter
    Jay
  11. Jul 7, 2021 at 3:25 PM
    #571
    skifishbum
    skifishbum Well-Known Member
    Reno, NV
    17 DCSB -> 22 DCLB
    285/70/17 and do not feel the need for a re-gear. Obviously requires a CMC if you do any dirt at all. Was told by a falken product manager their tires are on the burly side for their actual load rating (example he gave me - P Rated Wildpeaks = C rated K02s). looking at weights it make sense however YMMV and it could be marketing hype.
  12. Jul 7, 2021 at 7:02 PM
    #572
    Flashpoint
    Flashpoint Well-Known Member
    2017 Tacoma DCLB Quicksand
    275s
    CavalryTRD likes this.
  13. Jul 20, 2021 at 7:40 AM
    #573
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Does anyone have the 265/75/16 but in the LT tire? I keep seeing the same size but they’re all P write a tires and I got the LT ones so can anyone post pictures of the LT ones? Thank you
  14. Jan 13, 2022 at 3:27 AM
    #574
    Montana_Actual
    Montana_Actual ;)
    285/70R17 e rated
    3" Ironman stage 2 foam cell
    I am getting 5.29s and a tune.
    CavalryTRD, Merling and 908tacoma like this.
  15. Jan 13, 2022 at 7:33 AM
    #575
    Chzytaco
    Chzytaco Active Member
    Serg
    2017 Super White TRD OR 4x4
    KC HiLites G4 Fogs
    IMG_4183.HEIC.jpg Loving my 265/75/16!
  16. Mar 20, 2022 at 4:47 PM
    #576
    laftaco
    laftaco 2017 SR5 DCLB 4WD and 1996 LX 2WD
    Still no rubbing 3.5 years later?
    Landpirate[QUOTED] likes this.
  17. Mar 20, 2022 at 5:11 PM
    #577
    laftaco
    Thank you for posting Falken response.
  18. Mar 28, 2022 at 3:24 PM
    #578
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Going with these end of the week (my size is 31X10.5R15LT). My guy is throwing in alignment too for $860 out the door. Can't beat that
  19. Apr 15, 2022 at 9:02 PM
    #579
    ukraine49
    ukraine49 Member
    +1 on the Wildpeaks
    265/70/17 with stock suspension
    Thanks to Matt @Discount Tire for the help
  20. Apr 15, 2022 at 9:32 PM
    #580
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Did your truck come with those wheels or did you source them afterwards? If so, where'd you get em?
    Looks niiiiice
