Falken Wildpeak AT/3 tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeeptec, Aug 13, 2018.
  1. Aug 17, 2018 at 4:15 AM
    #141
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    No, they do not look the same. While having the same basic tread pattern, the LT variant has much larger lugs with far more space between them while also having larger shoulder lugs and sidewall tread. The LTs have a much more aggressive look. The P version of the tire is much more akin to the docile tires that come on the truck from the factory.
  2. Aug 17, 2018 at 4:46 AM
    #142
    82abnmedic
    82abnmedic Well-Known Member
    Florida
    2018 TRDSPLB
    Speaking strictly of load ratings on the 265/70/17
    OE 110 (Destination LE) : 2337x4= 9348 lbs.
    SL 115 : 2679x4=10716 lbs.
    LT 121 : 3197x4= 12776 lbs.
    For me, I dont haul much, and my trailer is 2700 lbs loaded. So Im good with the SLs. I dont rock crawl, and most of my offroad will consist of hardpack trail, fire roads, and sugar sand. In my case, the only benefit of a LT tire would be the looks. These are my SLs.20180813_164327.jpg
  3. Aug 17, 2018 at 5:52 AM
    #143
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Lol. No.
    RocTaco likes this.
  4. Aug 17, 2018 at 6:00 AM
    #144
    WZ00R2
    TN
    2020 Cement OR
    Most certainly yes. I was commenting on Toyo Open Country AT IIs not Falken Wildpeak AT/3s in reference to a questions a member had about them. They are manufactured in three different tread designs. Those being the more aggressive Extreme, the standard LT and the mild P version. All three having different dimensions concerning the tread design.
  5. Aug 17, 2018 at 6:00 AM
    #145
    JackofallMasterofnone
    JackofallMasterofnone New Member
    2018 TRD Sport dressed like a Pro
    Pro grille, TRD inspired wheels, dipped badges, upgraded minivan tires
    I got the package online at PMC tire. The brand is Replika. Free shipping and they came balanced and mounted. The wheels themselves were only $150 each and, to me, they look perfect.
    greengs[QUOTED] likes this.
  6. Aug 17, 2018 at 6:11 AM
    #146
    Lt. Dangle
    Ohio
    I should know better than to expect a response to be about wildpeaks in a fucking wildpeaks thread...
  7. Aug 17, 2018 at 6:23 AM
    #147
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Seems like most of these are coming from our Thailand plant not our buffalo plant
  8. Aug 17, 2018 at 6:25 AM
    #148
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Im sorry brother, I failed you on my original response to you.
    I double checked and I have the P rated version (SL), instead of the LT, as I had previously thought.
  9. Aug 17, 2018 at 6:26 AM
    #149
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    :thumbsup:
  10. Aug 17, 2018 at 6:28 AM
    #150
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Ive had four different tires on my Tacoma, factory AT 20s, Goodyear Amortracs, MS’2 and ATW3. The MS’2 and the ATW3 have great wet roadway traction and don’t require my to baby the throttle when accelerating from a stop on wet pavement. The AT20 and the Armortracs would slip even in moderate wet acceleration.
    Dogg23 likes this.
  11. Aug 17, 2018 at 6:35 AM
    #151
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Well they look great and the price is terrific. I'm so torn between these in 265/75R16 or 255/85s in another brand. If only they had these in the 255/85R16 size!!
  12. Aug 17, 2018 at 6:40 AM
    #152
    jeeptec
    jeeptec [OP] Active Member
    Eric
    2018 Metallic Grey 4door
    I size up tire
    I had my Wild Peat AT/3 tires installed yesterday. Quiet. Smooth. I also took measurements of my truck before and after. Gained 1/2 inch of lift.
    82abnmedic, shakerhood and Lt. Dangle like this.
  13. Aug 17, 2018 at 6:40 AM
    #153
    ZYBORG
    TX / S. FL
    3G TRD OR
    Here is an easy way to decide which one....
    Do you like your woman curvy? If so, 265 is your girl.
    Do you like your woman lanky? If so, 255 is your girl.
    :rofl:
  14. Aug 17, 2018 at 7:42 AM
    #154
    Chozer
    Chozer Well-Known Member
    NC
    2018 Tacoma TRD OR DCSB 4X4 V6 Auto
    For those who went up one size to the 265/75/16 from the stock 265/70/16 on a OR with these wild peaks on stock suspension.
    Specifically those with the OEM Toyota Mud Guards on the front and back. Any rubbing?
    I know those without mud guards seem to be fine, but I need to be sure no rubbing with mud guards.
  15. Aug 17, 2018 at 7:58 AM
    #155
    jeeptec
    Eric
    I size up tire
  16. Aug 17, 2018 at 10:17 AM
    #156
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    then I misunderstood, I thought you said no issues at all?...
  17. Aug 17, 2018 at 10:54 AM
    #157
    ZYBORG
    TX / S. FL
    3G TRD OR
    Trimming /molding and CMC needed in order to run my wheel / tire combo, is not what I would consider issues.
    The spacer kit itself has been flawless. No issues with the spacers themselves.
  18. Aug 17, 2018 at 1:13 PM
    #158
    dan_SD
    dan_SD Well-Known Member
    Daniel
    18' Cavalry Blue TRD PRO
    265/70/17s mounted!
  19. Aug 17, 2018 at 2:34 PM
    #159
    AArias1022
    AArias1022 Active Member
    NH
    2018 Cement Grey TRD Sport 4X4
    Installed today, 265/70R17 as well.
    113tac and SilverII like this.
  20. Aug 17, 2018 at 2:35 PM
    #160
    82abnmedic
    Florida
    2018 TRDSPLB
    Looks soooo much better!
