Falken Wildpeak at3w 265/75 R16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Dec 26, 2017.
  1. Dec 26, 2017 at 6:07 AM
    Dirty Harry
    Dirty Harry [OP] Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Merry Christmas to me! Loving the new tires, but I got about 15mpg on the way into work today... :eek:
    Fresh shoes mounted: IMG_2092.jpg
    Post mini-blizzard/slush pic: IMG_2117.jpg
  2. Dec 26, 2017 at 6:11 AM
    MedicResponse
    MedicResponse Member
    2016 Tacoma TRD Off Road
    Leer cap, TRD Exh, TRD Skid Plate, Araid Air, Duratrac
    Had these tires in a 10ply, rough ride but super reliable in all weather. Ended up changing out to Dura Trac C rating. Better ride and better gas mileage. Enjoy the Wildpeaks!
  3. Dec 26, 2017 at 6:19 AM
    Dirty Harry
    Andrew
    SW Florida
    Definitely a stiffer ride than before, which I'm okay with, but I'm a little concerned about the mpg.
    Thanks!
  4. Dec 26, 2017 at 6:21 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    I've had these same tires for about 2k now. Great ride on the highway and wet weather. 35 pi all around. I do notice that mpg is less, but if I drive with a lighter foot I can get near the same as with the previous 265/70/16 P rated stockers.Very happy with them.
  5. Dec 26, 2017 at 6:21 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Did you get the E or the SL ?
    Can you post a profile pic?
    I have these on the way!
  6. Dec 26, 2017 at 6:22 AM
    DavidM310
    DavidM310 Well-Known Member
    Temple, Texas
    2017 Tacoma/2015 4Runner/2015 IS250
    Looks good. That is the same tire I am going with on the same SR5 wheels as yours. Going LT-E load rating 265/75/16. I will be using them for camping/off-roading etc. I have Nitto Terra Grappler G2 265/70/17 P rated for daily driving, I couldn’t stand the decrease in MPGs from an E load tire. Hows the ride?
  7. Dec 26, 2017 at 6:23 AM
    Dirty Harry
    Andrew
    SW Florida
    Sure! Whats the exact angle you want?
  8. Dec 26, 2017 at 6:25 AM
    DavidM310
    Temple, Texas
    If you don’t like them, I’ll take them off your hands.
    I didn’t know they made them in C load. I think the weight for E load is 59lbs in 265/75/16 and 46 for SL-P.
  9. Dec 26, 2017 at 6:25 AM
    Dirty Harry
    Andrew
    SW Florida
    Its a bit stiffer than the stock Firestones, but handles our Missouri potholes really well. Haven't had a chance to take em offroad yet.
  10. Dec 26, 2017 at 6:44 AM
    gatriguy
    gatriguy Well-Known Member
    Paul
    GA
    2016 Black Tacoma SR5 DCSB
    I've put about 6k on my set of Wildpeaks and they have been great all around. I have 265/65R17 XL on some Fuel Mavericks. I was getting 22ish MPG on stock wheels for my 85mi RT for work, but thankfully have still been able to hit 20.7-21MPG with this set up. The ride is quieter and smoother than I expected too..
    NightHawkTaco420, vtown and DubfromGA like this.
  11. Dec 26, 2017 at 6:49 AM
    MFTAF13
    Bob
    NorCal
    13 MGM TRD OR
    Mine are an E.
  12. Dec 26, 2017 at 7:04 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    I went with the SL's they are a lot lighter / softer ... I just hope they look just as good!
    axisofoil likes this.
  13. Dec 26, 2017 at 7:06 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Just a profile / side shot.... something like this..
  14. Dec 26, 2017 at 7:17 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    I'm sorry, I miss informed. They are the "SL" load not "C" load. They do not make them in "C" in the size 265/75/16. The SL's are much quieter/softer/lighter than the Es (11lbs per tire). The only advantace to the E's is they far exceed the tow ratings of the SLs/truck.
    You might be in luck. Supposed to get these put on today but Im kinda second guessing the size I went with. Im thinking I should go ahead and go with 285s and do the CMC.
    If you are serious, I can be in touch.
    Btw, weight for the Es is at 55lbs per tire. Weight for the SLs is at 44lbs per tire.
    http://www.falkentire.com/tires/light-truck-suv-cuv-tires/wildpeak/t3w-tire
  15. Dec 26, 2017 at 7:22 AM
    Dirty Harry
    Andrew
    SW Florida
  16. Dec 26, 2017 at 9:20 AM
    Dirty Harry
    Andrew
    SW Florida
    I didn't realize that was the only thing preventing me from going with 285s. Even still, these guys are a huge improvement over stock. I may lift a few inches in the meantime and upgrade to 285s in 20-30k.
  17. Dec 26, 2017 at 10:53 AM
    dcgolfdr
    dcgolfdr Well-Known Member
    Alexandria, VA
    Beach towel in the drivers seat
    I too picked up these tires for Christmas, as well as some new wheels. They will be mounted up tomorrow and will post some pics.
    Dirty Harry[OP] likes this.
  18. Dec 26, 2017 at 11:10 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    7B270C11-E07A-47A0-B3AB-6003292E1799.jpg Sorry, lighting is difficult in shade with bright snow and sky. You can tilt the picture right to get a better perspective!
    Switched out stock Goodyears at 985 miles to Wildpeak AT3 265/75-16 SL. They’re great in snow/ice mix with 300 miles so far. Quiet and smooth on dry roads.
    I installed four Bilstein 5100s, .65 inch front, 1/2 inch spacer under rear axle, so just 1 inch total lift along with new tires.
    I liked the soft, compliant stock ride but not the body roll in curves.
    The new shocks transformed the vehicle to a stable and flatter ride on curvy roads with just a slightly firmer ride that is still soft and smooth over large speed bumps.
  19. Dec 26, 2017 at 11:11 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Yes, CMC and quite a bit of triming.
    I wanted to see them in person and go from there. I have seen 265/75/16s in person and they looked good. So we shall see if I keep them or do 285s but the 285s open a figurative can of worms.
    vtown likes this.
  20. Dec 26, 2017 at 11:15 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    Oh man, you can't tease us like that. You got a post up some better pictures!
