Falken Wildpeak at3w 265/75 R16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Dec 26, 2017.
  1. May 4, 2018 at 10:51 AM
    #241
    Hijynx
    Hijynx Well-Known Member
    Pacific Northwet
    2019 Offroad DCLB
    the placard in the door jamb for the stock tires. I'm not saying everybody needs to run the same pressure as I am. just answering the question of "what pressure are you running"
  2. May 4, 2018 at 11:39 AM
    #242
    valdomero
    valdomero Well-Known Member
    Valdo
    2017 Tacoma TRD 4x4 Offroad
    Plasti Dip Grille and Emblems Removed V6 badge
    I was at 35psi and I think that was too bumpy... I dropped it to 32psi runs good to me have trd offroad dcab 4x4
  3. May 4, 2018 at 11:47 AM
    #243
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    Trying to decide between these and 255/85r16 stmaxx. Guy could go crazy over tire selection!:frusty:
  4. May 4, 2018 at 12:23 PM
    #244
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    For whatever reason I was under the impression I had 265/75/16's lol, but I actually have 70's. Anyone know how well these tires(265/75/16) would do on stock suspension on a 16x8.5 wheel?
  5. Jun 20, 2018 at 3:42 PM
    #245
    cruiserhead
    cruiserhead Well-Known Member
    Curtice
    2018 TRDOR Cement DCSB. 1980 FJ40. 1978 FJ40
    These tires are nice. It's funny, when I look at pictures online, I don't think they look that good. But in person, they are very nice and exactly the aggressive look I wanted. Very pleased.
    Mine are newly installed, no lift yet, pic below. I want to do a mild lift, as I feel like these look a little bit stuffed in the wheel wells, but I don't want to go to big. Thinking 1.5" overall, front and back. Will that look good or bad in anyone's opinion? I'm worried 1" will not be enough, and 1.5" will look too big of gap. Thoughts? Maybe that isn't a big enough difference to worry about, so just go 1.5".
    Dee1seven likes this.
  6. Jun 20, 2018 at 4:57 PM
    #246
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
  7. Jun 20, 2018 at 10:59 PM
    #247
    cruiserhead
    Curtice
    Thanks! That looks really good. Based on that pic, I don’t think 1.5” will look too big.
  8. Jun 21, 2018 at 3:57 AM
    #248
    Dee1seven
    RVA
    @cruiserhead Thanks. I think it’ll look just right with 1.5” lift. I also have a AAL in the rear with the stock overload leaf in, that’s why you see more of the wheel well in the rear.
    cruiserhead likes this.
  9. Jun 21, 2018 at 4:44 AM
    #249
    cruiserhead
    Curtice
    Yeah I’m just going 5100 all around, with fronts set at 1.55” and 1.5” block in the rear.
    I’ve measured several times and for whatever reason, my Factory rake is almost level...1/2” to 3/4” rake. I see people going 0 lift in back and 2” up front. I’d have severe bro lean if I did that.
  10. Jun 26, 2018 at 11:24 AM
    #250
    rogue.tacoma
    rogue.tacoma Well-Known Member
    Ed
    2017 TRD Off-Road 4x4 DCSB
    Tried searching info with no luck, what PSI do you all air down to?
  11. Jun 26, 2018 at 11:37 AM
    #251
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    air down for wheeling? usually it's dependent on the obstacles, but around 12-15 for sand and 15-18ish for rocks/washboards.
    generally i'm running 36 up front and 32 in the back, but i might revisit that now that it's getting warmer.
  12. Jun 28, 2018 at 5:22 AM
    #252
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    For those running the non LT tire, have you taken it off-road like on trails, rocks, etc? I'd really want to pull the trigger on a set, but my only concern is the 4ply sidewall. Has anyone had issues out on trails with these getting sliced or popping?
  13. Jun 28, 2018 at 7:42 AM
    #253
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    that is the exact thing I would like to do, looks great...
  14. Jun 28, 2018 at 9:06 AM
    #254
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    I have a set of these on my 4runner on stock FJ suspension and they're nice tires. I do not do much offroading unfortunately. Maybe the occasional fire road trail. They look great and perform accordingly. Great city tires as well, pretty quiet. I will be contemplating on getting a set for a Tacoma this weekend if I pickup the truck. Not to mention, the pricing on these are very competitive. I think I picked mine up for $500 from a small local tire shop.
  15. Jul 19, 2018 at 3:24 PM
    #255
    Mayonayze
    Mayonayze Well-Known Member
    Got mine today, installer set them at 37 psi all corners. Chalk tested and it wore evenly. But seems like this thread likes a range of 32 to 35. Any updates?
  16. Jul 19, 2018 at 4:07 PM
    #256
    Dee1seven
    RVA
    @Mayonayze
    When I was running them I kept them at 32-33 cold once warmed up they went to 34-35 and that was perfect riding for me
  17. Jul 19, 2018 at 4:42 PM
    #257
    rogue.tacoma
    Ed
    I keep em around 34psi
  18. Jul 19, 2018 at 7:44 PM
    #258
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Low 30's cold, maybe 36-37 when hot.
    shakerhood likes this.
  19. Aug 23, 2018 at 8:10 AM
    #259
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    The wildpeaks 4 ply are what I run. They are a sandwiched ply which makes them tough like a 6 ply. Without the weight. Minimal new road noise. But I'm coming from a 10ply stt pro on my jeep. Impressions so far. They run great in the rain. They don't hydroplane over puddles like the duratracs do. They handle well in the dry and work well on dry and wet rock off-road. I find them ok in the mud, I'll air down and try them again. They clear mud reasonably well. The sidewall seems tough enough for me and I've drug them on rocks. The st maxx, most like are the worst tire I've ever used. They wear gross and are shit in the wet off-road.
  20. Aug 31, 2018 at 1:36 PM
    #260
    JAB4x4
    JAB4x4 New Member
    Installed a set of 265/75/16 on a 2018 TRD Pro stock suspension. I literally drove from the dealer to the tire store without going home. They look so much better then the stock Goodyears.
    Polythemus, csayno, bobrown14 and 7 others like this.
