Falken WildPeak AT3W on 17" TRD Pro Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shad951, Nov 7, 2019.
  1. Mar 8, 2021 at 2:59 PM
    #61
    jondoeski
    jondoeski Active Member
    2021 TRD SPORT DCLB
    Thanks for talking this out guys. Moving forward with Rekgens and will modify front spacer as required for wildpeaks at3s.
  2. Mar 11, 2021 at 5:05 AM
    #62
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    Did you get this sorted out?
  3. Mar 11, 2021 at 8:17 AM
    #63
    McCree
    McCree Active Member
    2016 Tacoma Sport DCSB Auto
    Have 265/70R17 Falken AT3W with stock suspension, stock rims.
    My mud flaps are RokBlokz (regular).
    No rubbing.
  4. Mar 11, 2021 at 8:20 AM
    #64
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Literally have the same tire with no suspension modification and the stock mudflaps and not even close to rubbing
  5. Mar 11, 2021 at 11:25 AM
    #65
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    kinda! I put the short spacer in the front and it didn’t rub! However I can see that since the flap is so stiff and inflexible and isn’t supposed to bend like that it’s stressing the screw hole where the spacer is screwed into. I’m going to hit it with a heat gun to see if the flap will contour more to the fender liner and alleviate some stress on the spacer. Thanks for the help though!! I didn’t think it was possible to run the rekgens without rubbing!
  6. Mar 11, 2021 at 11:27 AM
    #66
    NomadicCypress
    really?! I rubbed hard on the stock flaps under any sort of compression and even sharp turns in reverse. There was like a millimeter of clearance when the truck was on level ground.
  7. Mar 11, 2021 at 11:31 AM
    #67
    ryanvar42
    None
    265/70/17 and stock rims?? Right? Yeah, no rubbing at all.
  8. Mar 11, 2021 at 11:33 AM
    #68
    NomadicCypress
    Ah no I have the TRD pro sema rims! +4 offset. That’s where the difference is haha makes sense why yours don’t rub.
  9. Mar 11, 2021 at 11:34 AM
    #69
    ryanvar42
    None
    Yeah I think mine are like +26 or something like that.
  10. Mar 11, 2021 at 11:37 AM
    #70
    AJ`s Inferno Offroad
    AJ`s Inferno Offroad 2018 offroad fire ball
    Maryland
    2018 TRD Offroad inferno
  11. Mar 11, 2021 at 12:44 PM
    #71
    NomadicCypress
    stock suspension?
  12. Mar 11, 2021 at 12:46 PM
    #72
    jondoeski
    2021 TRD SPORT DCLB
    no chance
  13. Mar 11, 2021 at 2:56 PM
    #73
    Maryland
    No, just leveled the front to the rear
  14. Aug 8, 2023 at 7:29 PM
    #74
    brockleegreens
    brockleegreens Member
    2020 TRD Off Road
    Looks great! Considering the same wheel and tire combo. What lift do you have on your truck? What size tires did you end up going with?
