Falken Wildpeak Issues
Discussion in 'Wheels & Tires' started by appalachiantacoma, Mar 20, 2019.
  1. Mar 20, 2019 at 11:22 AM
    appalachiantacoma
    appalachiantacoma [OP] Member
    2017 TRD OR DCSB
    So I recently had Falken Wildpeak AT3W tires (265/75R16) installed onto my 16" Ray10 wheels at a local shop. I noticed that I had some shaking issues above 55mph so I took it back and had them rebalanced. This time the tires felt smooth with no shake until about 65mph but it seemed to only happen when the tires were cold, it was inconsistent tire balance issues.
    So I was frustrated and took it to a local Discount Tire to have them road force balance the tires and they said that all 4 tires came in under 30lbs variation and that was normal for a truck tire.
    To me that seems like it is too high, but they said there wasn't anything else they could change and that the tires were in balance. I am still getting a shake and now it seems to happen at various speeds and be somewhat related to temperature.
    At this point I kind of wish I went with a different tire, but there isn't a lot of options at 16" that isn't extremely heavy.
    Do you guys have any suggestions on what to try next?
    tony453rd likes this.
  2. Mar 20, 2019 at 11:28 AM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    what pressures are you running? mine had a slight shake at about 65, but seemed to correct itself in about 1k miles
  3. Mar 20, 2019 at 11:29 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I just had the same issue. A month ago I purchased a set of the exact same tires you have. They had a really bad wobble above 55mph. It was enough to shake the bed of my truck constantly. After SEVEN trips to the Discount Tire location I purchased them from to have them road force balanced and force matched, I made the choice to go with BFGs and couldn't be happier. The Wildpeaks I had were, by far, the worst tires I've had on a vehicle.
    gitacotrd and 2016Tacoman like this.
  4. Mar 20, 2019 at 3:42 PM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Interesting....glad I ran into this thread. I was really concerning buying these.
  5. Mar 20, 2019 at 3:45 PM
    SnowSpartan
    SnowSpartan IT, not the clown.
    Boise, Idaho
    2017 Gray DCSB TRD Sport
    I was told by DiscountTire and read on some other threads here that these tires don't play nice with some aftermarket wheels. Freeway shake is always the symptom, front or rear.
    These are the best tires I've ever ran. Just my opinion.
    Junkhead, Astr0Aar0n, lynyrd3 and 4 others like this.
  6. Mar 20, 2019 at 3:47 PM
    SnowSpartan
    Boise, Idaho
    I run 36 PSI all around on 265/70/r17. P rated SL. No issues. Too lazy to due the chalk test.
  7. Mar 20, 2019 at 3:47 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    265/75/16 Duratracs for the Win. C load and best rain rating....
    Kolter45, cgs2k2, DriverSound and 4 others like this.
  8. Mar 20, 2019 at 3:52 PM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    265 75 16 Wildpeaks for 28 K + - miles and still going strong. snow, summer, highway, frost heaves.. here and have been great, smooth no issues, oh and i am on aftermarket rims as well for all of it. For what its werth
  9. Mar 20, 2019 at 3:55 PM
    gmiller
    gmiller Member
    G
    Eastern TN
    2019 tacoma trd sport dcsb concrete
    Tacamo...
    Are those wheels painted, power coated or dipped? They look great.
  10. Mar 20, 2019 at 3:56 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Plasti dip. 2 winters now, no issues
  11. Mar 20, 2019 at 4:10 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    My Wildpeaks have been great. I think there might have been a lil shake brand new but went away quick. I've ran 36 psi in them also & on Method wheels. Got mine at Discount Tire & liked them enough to go buy a 5th wheel & tire for spare
    CementTRDOffRoad and medicfung like this.
  12. Mar 20, 2019 at 4:12 PM
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    2017 Black TRD OR 4x4 DCLB
    Fox 2.5 DSC Adjusters (Extended Travel), Camburg UCA, RCI Rear Bumper, Cali-Raised Zero Degree Step Rock Sliders (with filler plates), Softopper, TRD Pro Skid, Rigid, Baja and KC lights, H9 Headlight Upgrade.
    I'm looking at buying these exact tires. Are you guys running the C load or SL? I'm on stock rims.
    Kolter45 likes this.
  13. Mar 20, 2019 at 4:14 PM
    gmiller
    gmiller Member
    G
    Eastern TN
    Tocamo... just for clarification..."now"having issues, or "no" issues with the dip.
  14. Mar 20, 2019 at 4:16 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had mine mounted and balanced at the Toyota Dealer, no issues at all, very happy with these tires.
  15. Mar 20, 2019 at 4:19 PM
    medicfung
    richie
    for the record mine are mounted onto SCS SR8s. a little shake in the beginning, i was concerned it might be a thing, but it all went away rather quickly with a few hundred miles on them. so far, i like them better than the KO2s i ran on my tundra. quieter, and feel just as sticky if not stickier on wet pavement and dirt
    Lmckenz likes this.
  16. Mar 20, 2019 at 4:20 PM
    MrBrooks
    Midwest
    I have the SL 265/70/17 & were great this winter. Not sure I would have made it through this winter on the stock tires!!!
  17. Mar 20, 2019 at 4:56 PM
    WZ00R2
    TN
    2020 Cement OR
    Mine were on my factory OR wheels and they were absolutely terrible.
    InfernoChalupa likes this.
  18. Mar 20, 2019 at 5:00 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I have 265/75/16 falkens on oem pro wheels no issues also running falken 35/12.5/20’s on fuel wheels on my tundra again no issues...great tires
  19. Mar 20, 2019 at 5:00 PM
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    Has anyone contacted Falken directly about this issue?
    TXpro4X4 likes this.
  20. Mar 20, 2019 at 5:01 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Just an FYI, if you hit the quote at the bottom right corner it will notify the person you are try to talk to.
