Falken Wildpeak or Cooper S/T Maxx 255
Discussion in 'Wheels & Tires' started by yellowdogpaddler, Mar 13, 2018.
  1. Mar 13, 2018 at 8:46 PM
    yellowdogpaddler
    yellowdogpaddler [OP] Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    Initially I was looking at BFG KO2 but they are not available on Discount Tire Direct's sale on Ebay... I have read only good things about all three of these tire brands/models.
    The Coopers are a little more money $628 than the Falken Wildpeaks $448 for four...
    The Falkens are rated different from the other two with a "SL" rating. I can't find anything about this, what this means. I like what I have read about "C" rated tire and leaning in this direction.
    And- what does "LT" mean? I see this on the description sometimes and sometimes not depending on what website I am reading.
  2. Mar 13, 2018 at 8:52 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    I think I'm right by saying LT is light truck tire. Which will be a C rated tire or higher. I had the falken wild peaks for a little while in P rating. They had a great ride and were dead quiet. Obviously the sidewall was softer being a P rated tire. If you use them off-road I would suggest the cooper just because they are a bit more aggressive in the tread pattern. Either way on a 255 I would probably get a C load range or higher per personal preference and stronger sidewall assurance
    yellowdogpaddler[OP] likes this.
  3. Mar 13, 2018 at 8:53 PM
    1BDTACO
    1BDTACO Well-Known Member
    Joe
    North Dakota
    2017 Tacoma TRD OR
    OME Medium Lift, Fx Pro wheels, Falken at3 285/70/17
    Lt is a 10ply tire and c is 4 ply. The only real difference is amount of payload the tire can carry if you want a good ride go for the c tire.
  4. Mar 14, 2018 at 4:21 AM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    No...
    LT is "light truck" category... C, D, E load ratings..
    C is 6 ply..
    D is 6-8 ply..
    E is 10ply..
    Wildpeaks and STT are two different tires completely.. Hard to compare since one comes with an extra 1/4" of tread..
    I'm going to say go for the Wildpeaks in a P or SL...
  5. Mar 14, 2018 at 4:25 AM
    1BDTACO
    Joe
    North Dakota
    2017 Tacoma TRD OR
    My bad every 3/4 ton my job has is LT tires and they are all 10 ply. Figured thats what it was. Oh well.
    Pot_Lickr[QUOTED] likes this.
  6. Mar 14, 2018 at 4:28 AM
    FalconDriver
    FalconDriver Member
    AR
    ‘17 TRD OR DCSB
    I have experience with both the ST Maxx and the Falken, which I'm currently running. The ST Maxx is a superb tire for sure, but it honestly depends on your intended use, go figure right? The Falken in a P rating will be quieter and much more comfortable on the road. Unless you really need or want a 10 ply tire with beefy sidewall, the Falken will be the better choice for daily driving (noise, mileage, comfort). Hope that helps and good luck!
  7. Mar 14, 2018 at 6:00 AM
    yellowdogpaddler
    doug
    2018 DCLB OR
    Thanks FalconDriver. I am a photographer and will be carrying a lot of gear in the cab and in the bed on a regular basis. I will be driving this regularly, between a DD and for photo assignments. I have a Subaru Forester for running around town.
    I want to keep/get the best ride possible but use it for backcountry access in remote areas, e.g., forests, desert, Moab... and on a regular basis medium to long highway travel will be included.
    The Wildpeaks on TireSize.com are listed as "SL" so I am thinking this might be "C" since the weight carrying capacity is lower. I also wonder if carrying 500-800lbs on a regular basis would have any influence on the better route to go.
  8. Mar 14, 2018 at 8:31 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    SL (standard load) tires are 4-ply rated. As pot_lickr noted, C is a load range designation for LT (Light Truck) tires and are 6-ply rated.
    Details: Load Range & Load Index
    1Shifter, Fortunt1 and Pot_Lickr like this.
  9. Mar 14, 2018 at 11:37 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Assuming you’re talking about the Wildpeak AT3, then these aren’t available in 255/85/16 or 255/80/17 last I checked. I don’t believe the Wildpeak MT’s are available in 255 sizes either.
    Also, AFAIK, you can’t get a 255/85/16 or 255/80/17 in a C load range - they come in E only, which is 10-ply. This is good if you carry a lot of extra weight though or want better puncture protection but you’ll lose some mpg because E are heavier than C tires.
  10. Mar 14, 2018 at 11:40 AM
    yellowdogpaddler
    doug
    2018 DCLB OR
    They are available in 255/70 or 255/75... I am considering one of these sizes or even a 265/70 which BFG makes a "C" rated...
  11. Mar 14, 2018 at 11:42 AM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Ah, that makes more sense. When most people say 255 they’re referring to 33’s. Most of what I said is irrelevant then haha :p
  12. Mar 14, 2018 at 12:27 PM
    yellowdogpaddler
    doug
    2018 DCLB OR
    No worries... the more I twist myself around this the more I learn what I am looking for. In the end I won't know until I get out there and explore.... thanks for your input and advice, it all helps one time or another
    03 NIGHT TACO[QUOTED] likes this.
  13. Mar 16, 2018 at 10:32 AM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    I just got the Falken Wildpeaks from Discount Tire..killer deal! I do a lot of highway and off-road..so we will see shortly. The ride is SUPER quiet compared to my duratracs. It's like night and day and super smooth.
  14. Mar 16, 2018 at 12:20 PM
    yellowdogpaddler
    doug
    2018 DCLB OR
    Me Too!
  15. Mar 16, 2018 at 12:22 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    option c- cooper stt pros :thumbsup:
  16. Mar 16, 2018 at 12:26 PM
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    I would go cooper based on prior experience with the brand. I have the STT pros currently and my buddy got 55k out of his last set on his taco. For a mud tire that’s almost unheard of. They make some road noise, but to me it’s very liveable. If the mud tires get that kind of life, I’d imagine the maxx’s Are right up there as well
  17. Mar 16, 2018 at 2:46 PM
    Discount Tire
    Arizona, USA
    Thank you for posting your experience. We appreciate your business.
    Waaaa Whoooo, thank you for your purchase as well...
  18. Mar 20, 2018 at 4:19 PM
    motodh
    motodh Well-Known Member
    San Marcos, CA (North County San Diego)
    2017 DCLB OR
    Good to know, I ordered the same tires from Discount Tire. Any issues balancing the tires? I heard people recommend road force balancing the tires. Thanks!
  19. Mar 21, 2018 at 11:09 AM
    Discount Tire
    Arizona, USA
    Thank you for your business motodh, we road force balance all of our tires but have not had any issues with the Falken Wildpeak tires when it comes to balancing.
  20. Mar 21, 2018 at 12:53 PM
    rdtompk
    rdtompk Well-Known Member
    ST MAXX's in C-load 255/75 17's
