Fall Camp & Ride (Oct. 20-22, 2017)
Discussion in 'Florida' started by Taco No Baka, Jul 8, 2016.
  1. Jul 20, 2017 at 9:58 PM
    #1081
    Mitch2467
    Mitch2467 Teen with not much money
    Mitchell
    Tampa, Fl
    White 03 pre-runner
    Custom front bumper Ditch light, bumper light bar 33's 3 in lift Cold air intake Rock lights
    Also almost $600 :(
  2. Jul 21, 2017 at 6:06 AM
    #1082
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    You can cut bicycle inner tubes in half. Take the springs apart and use the inner tubes inbetween the leafs. This helps with squeaking. just mu .02 cents
    JaBoudy and 5 Lug Fury like this.
  3. Jul 21, 2017 at 6:56 AM
    #1083
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, PDL, Tilt, Cruise, AM/FM CD
    Yeah there's a thread on it around here somewhere. I like the chevys because they are spaced apart so they spray out easily. The all pros I found if you pressure wash them regularly and apply spray grease when drooped so it gets in between them, they stay quiet.
    TacoTRD78[QUOTED] likes this.
  4. Jul 21, 2017 at 12:09 PM
    #1084
    Manwho
    Manwho Still ignoring the voices in my head
    15 a/c sport 4x4 884/ bilstien front OME Dakar/Nitro-charger sport
    87 4runner 2in B/L N' shit 96 4runner back burner project
    Although I never tried it on Tacoma springs I used a dry graphite paint from tractor supply when I built my "Rears up front" pack for my 4runner. It's used on farm equipment that has metal sliding parts. Seems to work well for me anyway on old rusty springs.e slide.jpg
    Gettin Lost and Rattletrap66 like this.
  5. Jul 21, 2017 at 12:15 PM
    #1085
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    They also sell it at the autoparts store. It works well for loosening up 1st Gen sliding rear windows also. :D
    Edit: oh wait, the stuff I was referring to is just dry film lube, not paint.
  6. Jul 21, 2017 at 2:55 PM
    #1086
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 5 lug
    Got a lot of stuff lol
    I just spit on it
    :anonymous:
    JaBoudy likes this.
  7. Jul 21, 2017 at 5:55 PM
    #1087
    Manwho
    I'm glad you caught the difference because I didn't even think about that when I posted. This is a paint and I would not recommend anyone try to use it in the aerosol form with the leaves still on the truck. I meant it more as preventative measure if your worried a new leaf pack is going to squeak. They do make a paint on version that would probably work without removing the pack. I defiantly would not recommend it on your rear window:D
    TacoTRD78 and Rattletrap66 like this.
  8. Jul 22, 2017 at 12:28 AM
    #1088
    5 Lug Fury
    Kenny
    Knoxville, TN
    V8 5 lug
    Taco No Baka[OP] likes this.
  9. Jul 22, 2017 at 4:19 AM
    #1089
    Taco No Baka
    Lee
    Tampa, FL
    Okay, we now have 4 solo campsites looking for partners and 2 folks that haven't paired up with anyone as yet. @taco8603 @NABeast
    Hopefully we'll get some more folks to sign up and fill those gaps. :cool:
    TacoTRD78 and NABeast like this.
  10. Jul 22, 2017 at 5:55 AM
    #1090
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    What's going to suck is the ones who don't frequent the page will be up creek when they just show up
    JaBoudy likes this.
  11. Jul 22, 2017 at 9:29 AM
    #1091
    Taco No Baka
    Lee
    Tampa, FL
    Well, right now we have a bit of a cushion. But that is part of the reason I tagged Paul and Philip since I don't think they read every post in the thread. Philip seems like he doesn't check TW regularly anymore at all. :p
  12. Jul 22, 2017 at 12:53 PM
    #1092
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Well as of right now it looks like I may still be in Florida for this one. So if there is a free spot at someone's sight, and someone doesn't mind my 2 dogs. I could be the 2nd in their sight, If it happens that i can't go, I can PayPal you the other half for the sight .
    TacoTRD78 and Gettin Lost like this.
  13. Jul 22, 2017 at 1:02 PM
    #1093
    Taco No Baka
    Lee
    Tampa, FL
    Awesome! You have your choice between @Gettin Lost @FlyinRyan893 @Sholden223 and @5 Lug Fury . Take yer pick. I think all of them have said they will pair up with anyone that comes along. :cool:
    Gettin Lost likes this.
  14. Jul 22, 2017 at 1:06 PM
    #1094
    mosquitoTaco
    Anthony
    SouthTennessee
    Cool, thanks. And Whichever one doesn't mind dogs.
  15. Jul 22, 2017 at 1:12 PM
    #1095
    taco8603
    taco8603 Well-Known Member
    Philip
    Kenneth city Florida
    2019 White Tacoma DCSB SR 4x4
    lt265/75/16
    Can I share a site with someone I'll give them half the money when I get there
  16. Jul 22, 2017 at 1:12 PM
    #1096
    Taco No Baka
    Lee
    Tampa, FL
    Why would that matter? You don't have dogs. You have small horses. You could saddle them up and ride the horse trails with those things. If you broke down, you could harness them up and have them pull the Taco home. :rofl:
  17. Jul 22, 2017 at 1:24 PM
    #1097
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    I love dogs. I might be bringing my pup as well... He is great with other dogs as long as they don't bark aggressively or lunge at him. If your pups are friendly it would be no issues!!
    My boy is 80 pounds and friendly as can be. Very well trained. Has been socialized a bunch and loves to play with other dogs. He just doesn't take any aggressive behavior towards him very well.
    TacoTRD78 likes this.
  18. Jul 22, 2017 at 6:49 PM
    #1098
    mosquitoTaco
    Anthony
    SouthTennessee
    This is why I keep them, just in case something breaks :thumbsup:
  19. Jul 22, 2017 at 6:52 PM
    #1099
    mosquitoTaco
    Anthony
    SouthTennessee
    My dogs aren't agressive at all, just overly friendly, and the big one only barks for attention, never in aggression but I've seen other dogs take it otherwise, athough I think it's more of a size intimidation thing . He is a big baby
    Edit: if you remember, i was the one asking about the off leash dog training
    Gettin Lost[QUOTED] likes this.
  20. Jul 22, 2017 at 7:13 PM
    #1100
    Gettin Lost
    Florida
    2021 TRDOR
    Oh yea that's right! Yea man you can share my spot if you want. Shouldn't be any problem at all.
    And my boy has no issues with play barking... Just that growl/snarl type aggressive behavior... And he only proved it once...
    One time this lady thought it would be funny to let her pitbull run up to me and Battle (my dogs name) while i was letting him out to walk/potty at a rest stop... I had Battle leashed because it was the rule, the lady did Not... the pit was showing teeth and growling while running towards us... When the pit got to us my boy bit his throat and got on top of the pit.
    The lady was screaming. I pulled my dog off hers and loaded him into the truck. Walked up to the lady and told her she is very lucky to be a woman... Then i drove off... I try and keep him out of them type situations as much as possible now!
