Fall Camp & Ride (Oct. 20-22, 2017)
Discussion in 'Florida' started by Taco No Baka, Jul 8, 2016.
  1. Sep 7, 2017 at 11:23 AM
    #1201
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    I Think he was meaning condensor... which would make sense if it was in front of the radiator, and is clogged not allowing sufficient air pass through..
    but i don't know off the top of my head what order it's in.
  2. Sep 7, 2017 at 1:45 PM
    #1202
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    It's pretty much industry standard to have the condenser in front of everything else. Gives it the first crack at the cool air and makes the A/C colder.
    Also, if he was reporting a problem with the A/C not blowing cold, they might have told him the evaporator needed to be cleaned with as much playing in the mud as he does. It gets surprisingly muddy in there. I don't play in the mud that much but when I had my A/C system replaced, there was a lot of mud in the evaporator and housing.
  3. Sep 14, 2017 at 4:54 AM
    #1203
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Hey! I'm down for this years camp and ride, is anyone in need of a slot buddy or should I make my own reservation?
  4. Sep 14, 2017 at 8:26 AM
    #1204
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    @Taco No Baka
  5. Sep 14, 2017 at 12:11 PM
    #1205
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    I'm not going to be able to make it, sorry fellas.
    I cancelled my reservation so someone else can use the site.
  6. Sep 14, 2017 at 12:42 PM
    #1206
    TacoTRD78
    Stuart,fl
    That sucks was looking forward to meeting ya but life happens maybe we will cya in FEB. for the annual meet:fistbump:
    Key-Rei likes this.
  7. Sep 15, 2017 at 9:22 AM
    #1207
    JaBoudy
    JaBoudy Accidental Thread-Jacker
    Josh
    Florida
    1995.5 Tacoma 4x4 v6 5 spd 321k miles.
    -Fabtech 6" in front, OME/Toytec 5" rear with Dakar leafs. -Deck plate mod -Chassis Unlimited front bumper -Badlands 12k winch -33x12.50x15 BFG KO2's -15x10 American Racing AR-23's -Audio System -Kenwood Receiver -Powerbass PS12 -Rockford Fosgate R1 -Bridged Concept 65.4 Amplifier -Polk Audio component 5.5" door and 1" tweeter speakers -Polk Audio crossovers -JL Audio rear 6.5" speakers -Black-housed headlight with Amber SMD halo ring. -Exhaust Setup -2.5'' Pipe, cut cats, 18" MagnaFlow, dumped at the rear bumper.
    Sorry to hear you aren't going. I looked online and it said it's still reserved.Did anyone else grab it? I might have about 8 people (other tacomas/runners not on here) and would much rather nab a tent site near mine so we have 4 people at each site, not 8 lmao
    TacoTRD78 likes this.
  8. Sep 15, 2017 at 10:18 AM
    #1208
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I believe they only allow 2 people per site
  9. Sep 15, 2017 at 11:49 AM
    #1209
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Two trucks per site
  10. Sep 15, 2017 at 2:44 PM
    #1210
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yes that's what I said
  11. Sep 15, 2017 at 2:45 PM
    #1211
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Just to reiterate, it is two trucks per site. :D
  12. Sep 15, 2017 at 2:46 PM
    #1212
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yes two people with trucks per site
  13. Sep 15, 2017 at 2:48 PM
    #1213
    Trident904
    Brian
    17 4Runner TRD OR
    Okay. Two trucks per site.
  14. Sep 15, 2017 at 4:12 PM
    #1214
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Go back to buying stuff with your senior citizen discount
    Trident904[QUOTED] likes this.
  15. Sep 15, 2017 at 4:19 PM
    #1215
    Trident904
    Brian
    17 4Runner TRD OR
    You're not too far behind me buddy!
  16. Sep 15, 2017 at 4:34 PM
    #1216
    TacoTRD78
    Stuart,fl
  17. Sep 15, 2017 at 4:51 PM
    #1217
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Damnit
  18. Sep 17, 2017 at 7:28 PM
    #1218
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I'm in. 2 nights 4wd. Have not reserved a site yet
  19. Sep 18, 2017 at 6:57 AM
    #1219
    JaBoudy
    Josh
    Florida
    Two vehicles per site. $5 overflow parking available. Maximum 8 people per site. No limit on amount of tents, from what I see. :thumbsup:
  20. Sep 18, 2017 at 3:47 PM
    #1220
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Should I reserve my own site or is there anyone that needs a slot filled?
