Fall Camp & Ride (Oct. 20-22, 2017)
Discussion in 'Florida' started by Taco No Baka, Jul 8, 2016.
  1. Oct 18, 2017 at 5:47 PM
    #1521
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Thats about the best thing about silver, the pinstripes blend in alot better. Haha.
  2. Oct 18, 2017 at 5:48 PM
    #1522
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    They way I look at it its always going to be my truck Ill never get rid of it. So a few cosmetic scratches oh well. It dosent effect fit form or function and :itllbuffout:
    Key-Rei likes this.
  3. Oct 18, 2017 at 6:05 PM
    #1523
    TacoTRD78
    Stuart,fl
    Yeah Black is the worst for showing scratches. I have always liked black trucks. once you go black you cant go back.
    Key-Rei and NABeast like this.
  4. Oct 18, 2017 at 6:05 PM
    #1524
    timothyvalvo13
    timothyvalvo13 Member
    Tim
    2010 AC, 4x4.
    Aux. backup lights, Sound system overhaul.(may or may not have gotten wet)
    @Taco No Baka I'm Planning on coming dependent on if the body shop can hold up their promise, at least coming out for saturday, maybe staying the night. Like I said it all depends if I have my truck.
  5. Oct 18, 2017 at 6:07 PM
    #1525
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    @Taco No Baka I'm planning coming out Saturday for a little while.
    Taco No Baka[OP] and TacoTRD78 like this.
  6. Oct 18, 2017 at 6:12 PM
    #1526
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    JaBoudy and TacoTRD78[QUOTED] like this.
  7. Oct 18, 2017 at 6:16 PM
    #1527
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    That’s from Ocala which is twice as tight as Citrus
  8. Oct 18, 2017 at 8:38 PM
    #1528
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I dunno. Friday night's was kinda slow with ppl's brakes coming apart, other mechanical issues, and everyone getting out of their trucks every time we had to deal with an obstacle. The Saturday night run wasn't too bad though after Brian politely explained that sort of shit wasn't acceptable. :rofl:
    Yeah...I kinda give lie to that cliche. :D
    The OGT before I got her...
    And of course, the OGT now...
    And I'll never go back to black outside of an accent color. :cool:
    (In fairness, I won't do red or white either. :rofl:)
  9. Oct 18, 2017 at 8:45 PM
    #1529
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    I will "politely" lay down some "advice" before the night runs again if necessary.
    In fact, it may not be a bad idea to run 2 groups if there is a shit ton of people.
  10. Oct 18, 2017 at 8:55 PM
    #1530
    Sholden223
    Sholden223 Keep it Squatchy
    Spencer
    Webster FL
    2011 SR5 4x4 SQUATCH EDITION
    6" Fabtech DB lift 2.5 Dirt Logic coil over w/resi, 35's Toyo M/T, 18" Ballistic Sythe wheels, 2.5 Dirt 52" OSRAM LED light bar with Relentless Fabrication mounts, straight glass pack exhaust dumped at the axle, HID smoked fog lights, HID smoked headlights with halos and LEDs, Black low profile toolbox, Sasquatch Lightbar button, Rough Country pods
    Definitely need groups or at least 2 night rides
    JaBoudy and TacoTRD78 like this.
  11. Oct 18, 2017 at 9:02 PM
    #1531
    Taco No Baka
    Lee
    Tampa, FL
    @michaelrussell Tell your buddy not to worry. If he sinks the heavy chevy in a mud hole and I can't pull him out, there will be at least two winches there and I know the technique to double a winch's pulling power. A 9,500 lb winch can be made to pull 19,000 lbs if necessary with no extra strain on the winch.
    Not that I think the OGT is all-powerful or anything, but I pulled a buried F-Super Duty boom-type wrecker out of a mud hole that he burned up both his hydraulic winches attempting to pull him self out and I did it with an 81 Hilux (you know, the ones that only weighed about 2800lbs) with half-bald Goodyear Wrangler street tires and open/open diffs. I'm sure the OGT can do better being more than 1000lbs heavier, locked on both ends, and having "Wolverine Claw for tires" (that's never gonna get old :rofl:).
    Key-Rei and TacoTRD78 like this.
  12. Oct 18, 2017 at 11:26 PM
    #1532
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Well. Change of plans for me. I’ll be coming for Friday only. Going to show up around noon. Head home after the night run. Stupid work getting in the way...
  13. Oct 19, 2017 at 5:15 AM
    #1533
    TacoTRD78
    Stuart,fl
    So is the OGT is kinda like Michael Jackson... A new face lift and a color change but still black at heart?
    Key-Rei, Trident904 and LMarshall73 like this.
  14. Oct 19, 2017 at 5:57 AM
    #1534
    Trident904
    Brian
    17 4Runner TRD OR
    Did you just call the OGT a white woman? :rofl:
  15. Oct 19, 2017 at 6:01 AM
    #1535
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    what picture was in your sig?
  16. Oct 19, 2017 at 6:09 AM
    #1536
    Trident904
    Brian
    17 4Runner TRD OR
    It's the link to my build page. Why?
  17. Oct 19, 2017 at 6:14 AM
    #1537
    TacoTRD78
    Stuart,fl
    I refrenced Michael not Latoya
  18. Oct 19, 2017 at 6:14 AM
    #1538
    Taco No Baka
    Lee
    Tampa, FL
    Oh, no, you di'int just compare the OGT to Michael Jackson. o_O
    More like Zoe Saldana...
    Key-Rei likes this.
  19. Oct 19, 2017 at 6:18 AM
    #1539
    TacoTRD78
    Stuart,fl
    Much better choice Lee :thumbsup:
  20. Oct 19, 2017 at 6:23 AM
    #1540
    Taco No Baka
    Lee
    Tampa, FL
    F*%k me stupid! :frusty: I say we move the whole Camp & Ride to next weekend...
    allenfab likes this.
