Famous p0172
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrankFL., Jun 19, 2024.
  1. Jun 24, 2024 at 6:33 PM
    #101
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is the voltage the same with the light connected?
  2. Jun 24, 2024 at 6:38 PM
    #102
    FrankFL.
    FrankFL. [OP] Well-Known Member
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Nop. It drops when i connect the light
  3. Jun 24, 2024 at 6:40 PM
    #103
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So it really seems like a corroded wire or a bad connection, guess it's time to start examining the wiring between the PCM and O2 sensor for any suspect areas.
  4. Jun 24, 2024 at 6:45 PM
    #104
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Ok. Ill have to disconnect all the wiring and follow it trough until the o2 sensor. Can i use it with that code on? Wouldnt hurt the engine the o2 not reading or the system too rich?
  5. Jun 24, 2024 at 7:00 PM
    #105
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Shouldn't need to unhook much to do a visual inspection of most of the wiring, I've found alot of wiring faults with a simple visual inspection for any spots it could be rubbing on something, damaged, or evidence of a previous repair.
    As far as driving it the heater code wouldn't really concern me but the rich condition could possibly cause issues.
    I really want to get the O2 heater working properly though to rule that out as a cause of the rich code.
    Once we get O2 sensor working properly if we still have a rich code then we'll tackle that.
  6. Jun 24, 2024 at 7:06 PM
    #106
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    Ok thank you. Ill try to check i had the engine rebuild and had the wiring handy to check but never did this tests before. Ill have to check it on wednesday. Gonna use it to work tomorrow and wednesday morning and than stopping it again to check the wiring.
    Dm93[QUOTED] likes this.
  7. Jun 24, 2024 at 7:17 PM
    #107
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did all this happen, before, immediately after the rebuilt engine was installed, or sometime later?
  8. Jun 24, 2024 at 7:29 PM
    #108
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    I bought the car from an auction came with a dead engine. It wouldnt turn it had a crankshaft bearing stuck.
  9. Jun 24, 2024 at 7:32 PM
    #109
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ahh the fun of having no history on a vehicle.
    Did these codes pop immediately after getting it running or was it some time later?
  10. Jun 24, 2024 at 7:35 PM
    #110
    FrankFL.
    Franz
    2006 Toyota Tacoma
    Lift kit.
    It had a bunch of codes more. Had to replace crankshaft and camshaft sensor and vvti and bunch of other stuffs. Only problems remaining are those 2 codes.
  11. Jun 24, 2024 at 7:48 PM
    #111
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So you have made progress.
    We'll get it figured out, it may take us awhile but we'll get there.
    TnShooter likes this.
