Fan Blower Motor.... Again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rnhrtfan, Dec 31, 2019.
  1. Dec 31, 2019 at 4:31 AM
    Rnhrtfan
    Rnhrtfan [OP] Well-Known Member
    WV
    06 Super White DCSB TRD Sport
    Well, two weeks ago my blower motor would only work on high... changed the resistor and it works fine... until this morning... now it doesn't work at all... I am at work already so no time to diagnose right now. What do you guys think, where's the next most common issue?
  2. Dec 31, 2019 at 4:37 AM
    DG92071
    DG92071 Well-Known Member
    1. Fuse
    2. Fan motor
    3. Fan motor control switch
  3. Dec 31, 2019 at 4:39 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Did you replace the connector for the resistor as well? Look where it plugs in to the resistor. You will more than likely see one terminal that is discolored compared to the rest.
    VanDoom and NAAC3TACO like this.
  4. Dec 31, 2019 at 4:46 AM
    Rnhrtfan
    WV
    This was going to be my next steps...
    I did not replace the connector... the resistor I got did come with a new one but I didn't replace it. I will go there before and the fuse before looking at the motor and switch. Thanks to you both!
  5. Dec 31, 2019 at 4:56 AM
    Larzzzz
    Larry
    MA
    It came with the connector for a reason...
    Check the terminal on the resistor itself when you swap the connector out. It may need cleaning. Get a real crimp tool from home cheapo, Lowe's, or an electric supply house. Use the smooth crimp with insulated butt splices, and crimp them hard. Make sure the seam of the metal inside the butt splice is in the crimp die and not off to the side.
    Cut and splice one wire at a time, and stagger the splices so it doesn't look like a well fed snake when your done.
    Tacosail and Rnhrtfan[OP] like this.
  6. Dec 31, 2019 at 5:20 AM
    Muddinfun
    Muddinfun Well-Known Member
    Although you screwed up by not replacing the connector, that’s not your current problem. On a properly working truck, you can take the resistor out and throw it in the wood chipper and the fan will still blow on high. Your current problem is more than likely the blower motor connector.
    Too Stroked and DG92071 like this.
  7. Dec 31, 2019 at 5:26 AM
    DG92071
    Exactly, X2 (which I failed to mention in my post, lol).
  8. Dec 31, 2019 at 5:28 AM
    DG92071
    Both the connector for the blower motor resistor and the connector for the blower motor have known problems. Disconnect the plugs and look for burn marks on the connectors.
  9. Dec 31, 2019 at 5:44 AM
    Larzzzz
    Larry
    MA
    I was not aware of that the motor connector was also an issue. TIL
    DG92071 likes this.
  10. Dec 31, 2019 at 7:17 AM
    Taco'09
    Taco'09 Well-Known Member
    Ha, a pun (text color emphasis mine)?
    OP, I have used a kit from ACDelco that includes a new connector (at the resistor), resistor, and heavier gauge wiring with success. The entire HVAC system in our trucks is a General Motors special and the specific components a holdover from the days of the joint venture between Toy and GM. The kit was likely developed by GM and distributed through ACDelco because a lot of GM trucks have also had the same problem.
    orezona likes this.
  11. Dec 31, 2019 at 7:50 AM
    Rnhrtfan
    WV
    Thanks! My kit also came with the connector, resistor and heavier wires but my lazy A$$ decided not to change to connector. Should've just changed it too.
  12. Dec 31, 2019 at 8:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The terminals on the motor and resistor bridge fit loose and are prone to burning.
    Resistor and connector needed for the fan speed.
    Look at both connectors on the motor. I'd be willing to bet one or both of them are burned.
    If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    orezona, devkurf, JC15Taco and 2 others like this.
  13. Dec 31, 2019 at 8:24 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    I was lazy too, had this problem of fan not working on lower speeds and read about simply repositioning or tweaking the connection plug. Worked on two different trucks and it’s been over a year on one and 5 months on the other.
  14. Dec 31, 2019 at 8:26 AM
    Muddinfun
    Yeah! Jimmy to the rescue. You must have that text and pics on speed dial. LOL Every time I want to post it, I have to search for key words posted by you.
    Jimmyh likes this.
  15. Dec 31, 2019 at 8:47 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Thanks for the very complete information. If and when mine goes south, I'll be doing the job correctly now. Then again, also being an "old guy," I'm not so thrilled with the thought of cramming my body up under the dash like I used to when I was younger!
    Jimmyh[QUOTED] likes this.
  16. Dec 31, 2019 at 9:50 AM
    Rnhrtfan
    WV
    Thanks Jimmy! I already replaced the resistor and should have replaced its connector too but I didn't... So I will replace it tomorrow... I called the stealership and ordered the blower motor connector and the terminals a few minutes ago, they will be in on Thursday and I will go ahead and replace those as well... Looking at the blower motor, it looks like it has another connector that is similar in size and shape as the one that came with the resistor, should it be replaced as well? If so I will need to order it too.
  17. Dec 31, 2019 at 12:11 PM
    Larzzzz
    Larry
    MA
    I consider that man to be an encyclopedia Britannica of tacos... A valuable resource.
    Now, if we can only keep him out of banned camp. Lol
    Markcal, CurtB, Jimmyh and 1 other person like this.
  18. Dec 31, 2019 at 1:56 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm trying not to piss off anybody else or hurt anyone's feelings.
    :anonymous:
  19. Dec 31, 2019 at 2:13 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There are only two connectors for the blower motor.
    The four wire connector.
    and
    The two wire connector.
    The 4 wire is for the resistor and the 2 wire is for the motor connector.
  20. Dec 31, 2019 at 2:57 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    As an FYI. The resistor and it's connector have been updated again.
