fan blower switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by poppahank, Oct 29, 2018.
  1. Oct 29, 2018 at 10:25 AM
    poppahank
    poppahank [OP] Member
    henry
    2004 tacoma prerunner
    I am still trying to resolve a ac blower problem. I only get low speed, I changed and tested the resistor and it did not solve the problem. Anyone know how to check the control switch or how to remove and replace it. I appreciate any help
  2. Oct 29, 2018 at 12:12 PM
    bsedgal
    bsedgal Well-Known Member
    Ben
    Dallas, TX
    2002 3.4L Tacoma TRD
    normally when resistors go out, it only works on HIGH. Sounds like you have the opposite problem. Per the wiring diagram the high setting bypasses the resistor altogether.
    EDIT: sounds like a problem with the switch or the blower itself. Supply a jumper ground to the blower to see if it runs at full speed. If still slow, then blower is at fault. If fast, then switch is at fault.
  3. Oct 29, 2018 at 12:22 PM
    Glamisman
    Glamisman Well-Known Member
    for a 2003 but should be close.
  4. Oct 31, 2018 at 10:35 AM
    poppahank
    henry
    Tp bdsegal and Glamisman, thanks for the reply. I will have to figure out how to supply that jumper ground to the blower. I assume that I will have to get to the blower itself. Glamisman, does the schematic apply to 2004's also?
  5. Oct 31, 2018 at 11:29 AM
    Glamisman
    I do not know... someone with an 04 diagram could compare. Simple enough to check... check for voltage at the various blue and what ever the tracer color is out of the switch, If all 3 show voltage pull the blower motor, that should be easy also and hook it up to power and ground, it should run full speed.
  6. Oct 31, 2018 at 12:23 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Blower motor should be easy to get to under the glovebox. 3 screws hold it in and it drops straight down. Connector is on the bottom too. You either have to slide under or use a mirror and light.
