Fan clutch - 3RZ
Discussion in '1st Gen. Tacomas (1995-2004)' started by dalton9824, Mar 6, 2024.
  1. Mar 6, 2024 at 5:36 AM
    dalton9824
    dalton9824 [OP] Member
    Dalton
    2002 red single cab 4x4 taco
    None, stock.
    Is it normal for my fan to stay on constantly while driving or idling? The truck sounds like an airplane constantly and I’m leaning towards a bad fan clutch. It had a front end collision and I don’t think it was replaced.
    With that being said, do I need to replace the fan clutch? If yes, do I need to replace any other parts?
    My 2011 Chevy Colorado HAD to have the water pump done if you did the fan clutch, and vice versa. The old fan clutch destroyed my brand new water pump’s bearing within a week after replacement. Just don’t know if these 3RZ’s are the same way.
  2. Mar 6, 2024 at 6:33 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Did your fan have the radiator pushed into it? Was the fan replaced?
    You can just replace your fan Clutch if nothing else is damaged.
    wilcam47 likes this.
  3. Mar 6, 2024 at 7:23 AM
    dalton9824
    Dalton
    None, stock.
    The fan doesn’t look to be damaged. The radiator and fan shroud was replaced, but I don’t know if the fan was or not. Looks good to me, I just figured the fan clutch was bad since the fan doesn’t shut off ever.
  4. Mar 6, 2024 at 7:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Super simple to do a fan clutch test, could figure it out faster than these posts.
  5. Mar 6, 2024 at 7:26 AM
    dalton9824
    Dalton
    None, stock.
    How do you do a fan clutch test?
    I was gonna replace it anyways since I’ve never had a vehicle run the fan constantly. Mostly needed to know if there’s anything else to replace with the clutch
  6. Mar 6, 2024 at 10:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  7. Mar 6, 2024 at 10:16 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Love me a good lmgtfy.
    @OP If/when you decide to replace the fan clutch, RockAuto has good deals on the Aisin brand, which are basically OEM.
  8. Mar 6, 2024 at 10:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't know if the 5VZ options apply to the 3RZ, but FCT-013 is the heavy-duty variant I used on my Tacoma and 4Runner; this one has a green band.
    FCT-067 is the lighter duty; this one has an orange band.
    The difference being that the FCT-013 kicks on sooner for better cooling as it came with vehicle's that had the tow package.
    10 minute replacement, super easy. I've found them on Amazon for less than Rockauto many times.
    Takes a lot less to even check it as I mentioned.
