Fan clutch - how long can I run without fan clutch engaging on 2RZE
Discussion in '4 Cylinder' started by netsomnia, Sep 4, 2014.
  1. Sep 4, 2014 at 10:56 AM
    netsomnia
    netsomnia [OP] Well-Known Member
    Central/Eastern Missouri
    1998 2WD Tacoma 5 lug
    I have the 1998 5-lug 2WD model with 2RZE.
    I noticed the fan was wobbly and clutch not engaging about a month ago. I had some other repairs and upgrades to do and was not worried because my OBDII scanner indicated steady operating temperature at 185 degrees rain or shine this Summer. However, I know I should not run without for too long - and I don't want to be monitoring for temperature increase forever.
    How long can I run without a fan clutch? Will it create hotspots inside the motor if I runs too long without it? My son had a 1990 with 22RE that overheated and blew head gasket around the same time that the fan clutch stopped engaging.
    I do not have air conditioning and I only commute to work via highway. It is a plain, manual everything, green, pickup and my daily driver. It's growing on me and I want to take care of it with only 98K miles. The owner before me was a doofus :confused: and letting it go. Who knows how long doofus ran without a fan clutch engaging? I don't think I should be either.
  2. Sep 4, 2014 at 11:12 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Usually Toyota 4 cylinders are pretty cool running engines and with us going into cool weather you probably won't have a problem. But when you get ready to buy one this is the cheapest way I have found to get the OEM part without going to Toyota. Although yours seem quite pricey compared to the ones I have bought. According to my research this is the correct part # for your truck.
    http://www.amazon.com/Aisin-FCT-002-Engine-Cooling-Clutch/dp/B00829HAM2/ref=au_as_r?ie=UTF8&Make=Toyota%7C76&Model=Tacoma%7C1037&Year=1998%7C1998&carId=001&n=15684181&newCar=1&s=automotive&vehicleType=automotive
  3. Sep 4, 2014 at 5:46 PM
    netsomnia
    I agree with your comments and part number and saved that part in my Amazon wish list. Along with all of the other parts I could think of based on tips here and my experiences with 22RE in the past. Thanks.
  4. Sep 4, 2014 at 6:02 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    As long as you want...
    ...just don't stop.
    :rimshot:
  5. Sep 5, 2014 at 3:07 PM
    netsomnia
    Still holding at 183 degrees Fahrenheit after a bunch of stop and goes, but I agree that it needs to be fixed before the engine overheats and causes head gasket failure or something worse.
  6. Oct 6, 2016 at 5:43 PM
    netsomnia
    It's been 2 years on same aftermarket fan clutch that I used to replace the existing aftermarket.
  7. Oct 9, 2016 at 11:30 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I'd put Toyota stuff back on it especially since it only has 100k miles. Also if you ever take a fan clutch off leave it standing upright like it is installed in the motor or the oil will leak out and it won't work anymore
