fan clutch or radiator?? help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by kjp535i, Aug 11, 2010.
  1. Aug 11, 2010 at 6:30 AM
    kjp535i
    kjp535i [OP] Member
    Kevin
    Mobile, Al
    96 Tacoma
    truck overheating over long period of time. doesn't go to red or anything, but does go well above normal. accelerating will make it go down, but will eventually go up again. turning the heater on will also make it go down. pretty sure it is the fan clutch or the radiator. anyone know a sure fire way tell which one???
  2. Aug 11, 2010 at 7:07 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    What yr truck?
    Is the fan belt missing? or coolant level low?
  3. Aug 11, 2010 at 7:15 AM
    kjp535i
    kjp535i [OP] Member
    Kevin
    Mobile, Al
    96 Tacoma
    everything is up too par..... trying to let the engine heat up now to see if I'm able to stop the fan.
  4. Aug 11, 2010 at 7:45 AM
    kjp535i
    kjp535i [OP] Member
    Kevin
    Mobile, Al
    96 Tacoma
    I can however have the radiator cap off at normal running temp. not seeing much movement in the water if any. should i see it moving?
  5. Aug 11, 2010 at 1:49 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    That depends on if the coolant temperature is hotter than the thermostat opening temperature. At normal running temp the thermostat may stay closed until the temp rises.
  6. Aug 11, 2010 at 7:13 PM
    TGurau
    TGurau Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    I had the same problem a few months ago. It ended up being both, but I knew the fan clutch was bad because I could stop the fan with my bare hands while the truck was running. Try to CAREFULLY stop the fan clutch with a rag or something and if u succeed, change it. If the problem persists, change the radiator too (I did both).
  7. Aug 11, 2010 at 7:17 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Typically, truck overheating at highway speed but not at low speeds in town points to a radiator issue. If it only overheats at lower speeds in town, typically a fan issue.
  8. Aug 11, 2010 at 7:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    X2 ,
    Yep smart money says its a stat issue......
    Also check your hoses for soft spots......:cool:
  9. Aug 11, 2010 at 7:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & I wouldn't recommend EVER putting any body part/foreign object into anything spinning on the motor when its running (even if you've been getting away with it) You don't have to in order to check the fan clutch, With engine OFF you can grasp the fan blades & check for side to side slop if you have an excess , fan probably on its way out, if you can't turn the fan at all with hands, the fan clutch is history, if you have relatively smooth resistance when turning the fan, the clutch is good & your problem is else where......:cool:
  10. Aug 11, 2010 at 8:04 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    check your clutch fan with it off? my froze up but didnt cause overheating
    x3 on stat
    not flowing
  11. Aug 11, 2010 at 8:17 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well if it froze up, like I said the clutch is history & can you imagine what would happen to your hands/arms if as suggested "try to stop the fan with your hands or use a rag" ?
    Remember the fan is froze & the motor is running (but you don't know the fan is froze yet thats why you're testing it )
    Now put your hand down there & try to stop it !! :eek::eek::eek:
    Like I said do it with the engine off...;)
    We already agree on the stat though..:D
  12. Aug 11, 2010 at 8:22 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    My dad told me when I was a kid he knew a guy that was working on his car and his shirt got caught in the fan blade and sucked his arm in.( A metal fan blade too= No Arm.) No Joke either. Touching a fan blade at 1000 rpms may not be too safe.
  13. Aug 11, 2010 at 9:19 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    i had a similar issue a while ago, I ended up having a bad thermostat and fan clutch, and for safe measure and because it was cheap, the radiator cap.
  14. Aug 12, 2010 at 9:14 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    In my defense, I was wearing mechanix gloves when I did this and I found it out by accident. One thing i did notice when i changed the fan clutch is the air flow. There should be a lot of airflow coming from your engine when it's on. If there isn't... well, that's self explanatory.
    I changed the thermostat too, it didn't help. It was the first thing i changed. Also, this whole highway/city driving idea isn't supported by my experiences. I had a bad fan clutch and a bad radiator and when i changed the fan clutch (i did this first) i still had overheating issues on and off the highway.
  15. Aug 13, 2010 at 8:01 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    What about the sending unit giving a false reading?
  16. Aug 13, 2010 at 5:13 PM
    kjp535i
    kjp535i [OP] Member
    Kevin
    Mobile, Al
    96 Tacoma
    You guys are all crazy!!! I never said i stopped it with my hand!!! I used my friends hand... I'm not that stupid..lol
  17. Aug 13, 2010 at 7:23 PM
    desertdude59
    :thumbsup: lol
