Fan Clutch Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by iliketurt13s!, Nov 18, 2017.
  1. Nov 18, 2017 at 9:55 AM
    iliketurt13s!
    iliketurt13s! [OP] New Member
    03 Tacoma SR5
    Need to replace the fan clutch in my 03 Tacoma (orange housing) without the towing package.
    Has anyone installed a tow-package (Green) fan clutch on a non-tow package tacoma before? If so do you also need a different pitched fan blade? Couldn't find a different blade on rock auto. Already have the external transmission cooler and just looking to improve the life of the truck. Thank you
  2. Nov 18, 2017 at 10:18 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I have. I didn't notice a difference in the fans. I believe the tropical (tow) clutches just engage at a lower temperature.
  3. Nov 18, 2017 at 10:21 AM
    iliketurt13s!
    03 Tacoma SR5
    Okay thank you. You reused the original fan blade right?
  4. Nov 18, 2017 at 10:27 AM
    License2Ill
    Ian
    No. I'm pretty sure I reused both the green clutch and it's OG fan.
  5. Nov 19, 2017 at 7:29 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I have swapped a green one on my truck without a tow package. Used the same fan that was on my non tow package truck.
  6. Nov 19, 2017 at 10:26 AM
    Glamisman
    Glamisman Well-Known Member
    why do you "need" to replace it? Is it leaking the silicone fluid or? They are servicable, it just depends on if you want to spend the time tinkering or not. I have had more sucess's than failures in serviceing them but then I didnt wait until it started to leak.
    GQ7227 likes this.
  7. Nov 20, 2017 at 2:59 PM
    iliketurt13s!
    03 Tacoma SR5
    It fails to engage resulting in the truck overheating a low speed or stoplights. I took a look at the clutch I did not see any silicone fluid coming out of it. I ended up ordering the tow package clutch from Rock Auto. Hopefully this will fix the overheat issue and fingers crossed that I caught it in time and didn't do further damage to head gasket or other engine components. Thank you all for your responses
  8. Nov 20, 2017 at 4:22 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    GQ7227 and cali04intx like this.
