Fan clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaLady31, Oct 24, 2016.
  1. Oct 24, 2016 at 1:12 PM
    TacomaLady31
    TacomaLady31 [OP] Member
    Mikki
    1999 Toyota Tacoma Trd
    Shocks,struts, bigger tires, stereo system
    I have this grinding noise that is coming from the fan/belt area. Could it be the fan clutch goin bad
  2. Oct 24, 2016 at 1:45 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Could be. But I think it's more likely that a pulley would be making a grind type noise.
  3. Oct 24, 2016 at 1:49 PM
    TacomaLady31
    Mikki
    Its a hard noise to describe. But thank you :)
  4. Oct 24, 2016 at 2:10 PM
    cruiserguy
    Elijah
    SLC
    Now that I think about it, the water pump pulley, that the fan clutch itself is bolted to, could be making your noise as well.
  5. Oct 26, 2016 at 8:39 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    On a V6 the water pump pulley is completely out of sight. It is behind the timing cover and is driven by the timing belt.
  6. Oct 26, 2016 at 8:43 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    try turning the clutch fan with the engine OFF. It should turn with some resistance if its grinding you should be able to tell.
  7. Oct 26, 2016 at 8:49 AM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Littleton
    01 TRD
    I had a light grinding noise coming from that area. Ended up being the bracket that the fan bolts on to.
