Fan clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Aug 22, 2021.
  1. Aug 22, 2021 at 8:37 AM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello good afternoon everyone I have a questions my fan clutch is going bad and wanted to see which brand is the best to replace it with and maybe while I'm at it should I replace any other parts. thanks . 2004 Tacoma V6 152000 miles automatic
  2. Aug 22, 2021 at 8:38 AM
    Tacomaislife
    Texas
    2002 tacoma trd
  3. Aug 22, 2021 at 9:41 AM
    1997tacomav6
    Denver
    Rock auto the Aisin maker with the green painted hub is the heavy duty one.
  4. Aug 22, 2021 at 9:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Aug 22, 2021 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As mentioned, Rockauto offers an Aisin fan clutch as does Amazon (sometimes cheaper).
    FCT-013 is the 'green' variant that's meant for vehicles equipped with the tow package. I went this route due to all my goodies added.
    FCT-067 is the 'orange' variant that's lighter duty.
    It's like a 10-minute job -
    1997tacomav6 likes this.
  6. Aug 22, 2021 at 10:23 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP what has led you to believe the clutch is going bad?
    Digiratus and Kwikvette like this.
  7. Aug 22, 2021 at 12:57 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Mechanic stopped it with his hand said it's not supposed to do that
  8. Aug 22, 2021 at 12:59 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Since mine doesn't have tow package but I do Carry have stuff sometimes should I get the fct 013 even though I don't have the tow package?
  9. Aug 22, 2021 at 1:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I did.
  10. Aug 22, 2021 at 1:08 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Okay I'ma go that route thanks man
  11. Aug 22, 2021 at 1:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This sounds like bad advice. When the truck is fully up to running temps and not overheating, one trouble shooting technique is to gently (and carefully) stop the fan clutch assembly from spinning to verify it is working correctly. IMO, stopping the fan from spinning using your hand is a reckless move and could easily break the plastic fan.
  12. Aug 22, 2021 at 10:07 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    have you ever replaced the fan bearing. That's one thing I'd change while your doing this job. If it fails, it can do quite a bit of damage.
    Tacomaislife[OP] likes this.
