Fan for heater and AC does not work suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruben526, Jun 27, 2016.
  1. Jun 27, 2016 at 2:22 PM
    Ruben526
    Ruben526 [OP] Well-Known Member
    Ruben
    Salem, Oregon
    2001 Tacoma SR5 Prerunner
    Solo MOTORSPORTS LT basic kit with king 2.5 8” coilovers Advanced fiberglass fenders all around Deaver J59 springs with rear shock relocation to outside frame 14” 2.5 sway away triple bypass sway away 2” 2.5 bump stops 35” general grabber X3 17” addicts Total chaos spindle gussets
    So about a week ago with my AC on at medium it stopped suddenly then started again for about a min then stopped and will not turn on at all. Trying to finger out what I should replace or do and if anyone had similar problems? Also I checked my fuses only one I see that could be AC that I seen was was marked ACC idk if that is accelerant or something else. my truck is a 01 Tacoma prerunner SR5 2wd. let me know what you guys think thank you!
  2. Jun 27, 2016 at 3:56 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Break out the Meter check the voltage at the blower Motor .
    If you have system voltage time for a new blower motor
    If it works only on High good chance the Resistor is open
    If no voltage check if you have it at the blower switch .
    Go from there .
    robssol likes this.
  3. Jun 28, 2016 at 1:28 AM
    Ruben526
    Ruben
    Salem, Oregon
    Thank you man, i will check those out and it does not work on high not at all on any level
  4. Jun 28, 2016 at 1:57 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Try this... Find the blower fan housing. Can't remember what it looks like in a 1st gen, but in a 2nd gend it is a round, black, plastic piece approx 6in in diameter. Probably up above the passenger footwell. Have the fan on high and give it some love, smack it around a bit just hitting it with your hand. Let us know what you find out. The blower motor itself could be giving up the ghost.
  5. Jun 28, 2016 at 3:46 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    locate the blower motor under dash behind glove box and connect 12v to it and if it works the fan is good and check the resistor relay (also right there by the fan) and see if you have 12v to it, if you do then the resistor is bad, if no voltage there then it could be your main climate control (3 switch panel) has crapped out on you
  6. Jun 29, 2016 at 7:15 PM
    Ruben526
    Ruben
    Salem, Oregon
    Thanks brotha will check out tomorrow, I Appreciate it!
  7. Jul 2, 2016 at 2:19 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So what did you find? :popcorn:
    I only ask since my meter is a POS and I need to pick up a new one... my system had the same exact symptom today but it came back and so far its working fine.
  8. Oct 21, 2016 at 3:31 PM
    Ruben526
    Ruben
    Salem, Oregon
    That's funny because I was about to take it apart then on my way to work about a week later it just started working fine all by it's self again and has been working ever since!
  9. Oct 21, 2016 at 3:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Winter is coming. If you need heat where you live, dig in now and find the problem while the weather is good.
    Ruben526[QUOTED][OP] likes this.
  10. Oct 21, 2016 at 3:42 PM
    Ruben526
    Ruben
    Salem, Oregon
    Yeah exactly I plan too I'm about to have time on my hands soon with fire season hopefully coming to an end so I can focus on my truck and get all that situated haha
  11. Aug 8, 2017 at 9:52 PM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    The fix for me was simply removing the electrical connection to the fan, cleaning the contacts on both, and put it back together. 100k miles on the truck now.
    Before that I checked and had 12v to the fan measured at the connector. So I knew it was either a bad fan or the connections were corroded - the latter.
