Fan only works on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by golfvt1, Dec 1, 2015.
  1. Dec 1, 2015 at 4:48 PM
    golfvt1
    golfvt1 [OP] Member
    2009 4wd double cab
    none
    it is getting cold in sunny VT, have fan issues. Fan only works on high, occasionally for the rest of the spectrum but not reliable enough. I think it is the switch, how do I replace it? I also have some dead lights for my switches...how do you replace them.
    Thanks guys..I have been driving toyota trucks for 34 years, the 22r's were easier to work on.
  2. Dec 1, 2015 at 4:49 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Could be the blower motor resistor, it's a common problem
    shakerhood likes this.
  3. Dec 1, 2015 at 4:54 PM
    golfvt1
    golfvt1 [OP] Member
    2009 4wd double cab
    none
    How do I check the resistor?
  4. Dec 1, 2015 at 4:57 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  5. Dec 3, 2015 at 6:24 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Wiggle the resistor plug first while in a mid speed and see if the fan starts. Do a search, LOTS of info on this. Bad resistor, bad/melted connector, and loose pins in the connector are all possibilities.
