Fan Shroud Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wade50, Feb 12, 2022.
  1. Feb 12, 2022 at 7:15 AM
    wade50
    wade50 [OP] Member
    Chesapeake, Virginia
    2013 Toyota Tacoma 4WD 4 Door TRD Off Road
    Total Chaos Bed Stiffener
    Anyone have a video for the proper way to remove fan shroud on 2013 Tacoma w/ 4.0??Thanks!
  2. Feb 12, 2022 at 7:36 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not much to it.
    Remove the 9 push pins along the top cover with a flat screwdriver or other suitble tool.
    Remove the 2 nuts (10mm) holding the top engine cover on and remove the cover.
    Disconnect the overflow bottle hose from the raditor.
    Remove the 2 bolts(10mm) holding the fan shroud to the radiator.
    If you have an automatic I believe the transmission cooler hoses are clipped to the bottom of the fan shroud in a plastic bracket, unclip that from the shroud.
    Remove the 4 nuts (12mm) holding the fan clutch to the water pump.
    Lift out the fan, fan clutch and shroud together.
    TnShooter and wade50[OP] like this.
  3. Feb 12, 2022 at 8:46 AM
    wade50
    wade50 [OP] Member
    Thanks for the response. I follow the measure twice cut once rule.
    Dm93 likes this.
  4. Feb 12, 2022 at 1:30 PM
    caribe makaira
    Caribbean, Puerto Rico
