Fan Shroud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverSeven, Mar 4, 2009.
  1. Mar 4, 2009 at 8:08 AM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    how important is the plastic fan shroud on the 05-09s?
    I recently fractured mine on the trail, only a bit, but enough that i had to break part of it off because it was getting in the fan. Well now it is loose on there and just junky, I would like to just remove it, but heard it could lead to overheating. The shroud looks meaningless, but before i take it off i want to know if its a bad idea. I will replace it if so.
    Thanks
  2. Mar 4, 2009 at 8:37 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Replace it. The fan blade sucks air through the radiator, Without the shroud, the fan is not as effective and you could overheat.
  3. Mar 4, 2009 at 8:41 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    correct... the shroud makes sure that all the air the fan is pulling goes through the radiator first, thus cooling the radiator.. so yes it is important
  4. Mar 4, 2009 at 8:44 AM
    SilverSeven
    Jordon
    South Jurzee
    ok i see. anyone know a good place to get one? i did google it, but sometimes millions of options are worse than a few good ones
  5. Mar 4, 2009 at 8:46 AM
    martie
    martie mjp2 is living vicariously through me.
    smartie pants
    NJ
    2015 Ford Explorer Sport
    I don't know specifically if there's one place better than another but Mike just had to replace my fan shroud and we got it from partsgeek.com. They ship out of NJ and we got the part next day.
  6. Mar 4, 2009 at 8:54 AM
    SilverSeven
    Jordon
    South Jurzee
    sweet checking that out! did he have to take off the whole front end? or did it slide in there nice?
  7. Mar 4, 2009 at 8:56 AM
    martie
    smartie pants
    NJ
    This was on my car so I'm not sure how it'd translate to the Tacoma.
  8. Mar 4, 2009 at 9:13 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I would also go with replacing it since you offroad. If you were mostly a highway cruiser, then you could probably do without it.
  9. Mar 4, 2009 at 9:15 AM
    Fire931
    VA
    00 4Runner
    to replace it all you have to do is first remove the fan, this requires loosening the 4 bolts that hold the fan and pulley to the water pump. most likely can do this without removing the belt if your careful. then unbolt the fan shroud and slide the fan and shroud up and out.
  10. Mar 4, 2009 at 9:46 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Ahh its just a little crack:rolleyes:. :D
  11. Mar 4, 2009 at 9:50 AM
    SilverSeven
    Jordon
    South Jurzee
    haha yeah..maybe ill just ducttape it
