Fan speed knob
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ronnied78, Oct 26, 2024.
  1. Oct 26, 2024 at 11:25 AM
    Ronnied78
    Ronnied78 [OP] New Member
    2018 Tacoma
    My son put on the aluminum covers that are colored. When removing the from fan speed control knob on his 2018 he must have broken something because now the knob spins freely and won’t click through the speeds. I’ve googled this and can find nothing to try and fix or replace that knob.
  2. Oct 26, 2024 at 1:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If you can’t fix the knob yourself, you’ll probably have to replace the whole control unit. Check online parts sites to confirm, I could be wrong.
  3. Oct 26, 2024 at 1:40 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    if you cant tell if its broke by looking at the knob and where the knob goes then seek professional help
    time to google a repair shop
  4. Oct 26, 2024 at 1:54 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
  5. Oct 26, 2024 at 2:07 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Does the shaft without the knob on work? Does it click properly without the knob on? Maybe the splines on the knob have been damaged. If so then you can probably jury rig something to make the knob fit tightly on the shaft. Something as simple as wrapping the shaft with some plumbers tape or use a couple thin pieces of material such as tooth picks inside the knob.
