Fan speed switch not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbmcmahon, Jan 17, 2010.
  1. Dec 12, 2016 at 1:46 AM
    #241
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes this is what you need:
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each.
    Connector:
    Terminals:
    davids540i likes this.
  2. Jan 7, 2017 at 12:11 AM
    #242
    pepseeguy
    pepseeguy New Member
    Randy
    2009 White Tacoma TRD Access Cab
    I ordered the new resistor and connector plug/wires. I wound up not needing the plug/wires. But, the resistor was toast (it was the one that came in my truck when I bought it new & it was the one from Slovenia!) Anyway, the blower motor was shot too! I'm keeping the wire in case I ever need it in the future (it was only $17). New resistor & blower & motor and I'm back in business! Thanks for all of you help folks!
  3. Jan 7, 2017 at 10:57 AM
    #243
    dwalbert
    dwalbert Member
    2010 Tacoma Double Cab 4x4 SR5
    I agree, great thread. I only had to replace the Resister, Blower (current part # 87138-04052) with my old one. I ended up popping the 50amp fuse in the engine compartment fuse box (#29), but after I replaced the fuse, everything worked. I had the same issue with the blower only working on high. 2010 4WD DBL Cab.
  4. Jan 10, 2017 at 7:20 AM
    #244
    badgerhoney
    badgerhoney Member
    james
    2011 tacoma V6 SR5
    Where did you buy the connector? I've called every auto store in my area and none of them carry the connector, pigtails, or the resistor! Apparently I have to go to dealership. Not looking to spend hundreds. Could you send the info on where to buy these??
  5. Jan 10, 2017 at 7:28 AM
    #245
    badgerhoney
    badgerhoney Member
    james
    2011 tacoma V6 SR5
    At first I thought the fan was totally shot until I started to Wiggle wires around. Fan still works but at times I have to wiggle the connection. Going to clean this up and apply bulb grease to hopefully buy sometime before it blows my resistor. Anyone know where I can buy all these parts? Called every where. No luck.
  6. Jan 10, 2017 at 8:00 AM
    #246
    Marcus Israd
    Marcus Israd Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
    Any ideas on why the opposite might occur? All settings except "high" work on mine.
  7. Jan 10, 2017 at 8:32 AM
    #247
    badgerhoney
    badgerhoney Member
    james
    2011 tacoma V6 SR5
    Have you inspected the cabin filter? Mine was disgustingly black and I'm assuming that's why my connector is fried. Check your cabin filter. If it's dirty as hell, that maybe the problem. If it is decently clean, leave it out and turn the trucks electrical system on. Don't start the engine, just turn the key to the "on" position. Turn your fan on HIGH and listen for the fans motor. If you can hear the fans motor running but the fan isn't moving, check your connector.. I'm no electrical engineer but these forums are extremely helpful! Probably better than YouTube lol
  8. Jan 10, 2017 at 3:26 PM
    #248
    Jimmyh
    SC
    2012 Prerunner SR5
    Looking at a web search for these part numbers show a price of about 6 dollars each at places like Camelback Toyota etc...
    I would order genuine parts through an online dealer or go to the locale dealer..
    They are also on ebay at a higher price.
  9. Jan 10, 2017 at 3:31 PM
    #249
    Jimmyh
    SC
    2012 Prerunner SR5
    There ain't no cleaning going to help with that mess.
    There is no such thing as bulb grease. What you are referring to is actually Dielectric Grease and is not intended to be applied to the contacts as it is an insulator that does not conduct current. It is intended to seal water and contaminates out of an environmentally exposed connector.
    No. That is incorrect.
    A blocked fan will pull less current than an unblocked fan because it is not doing any work.
    Your problem is the terminals are loose adding resistance and generating heat. Get the replacement connector as posted above and repair it before it damages more wiring.
    <<< Electronics And Automation Technician.
    badgerhoney[QUOTED] likes this.
  10. Jan 11, 2017 at 6:32 AM
    #250
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    My resistor at the fan was bad for so long it burned the switch. So after doing the resistor and wire replacement I had to replace the fan switch assy. I got it from a wrecking yard and funny thing is I tried 3 different ones from the wrecker and all three my temp is now backwards but works great. So don't wait to replace the resistor at the fan...it may burn the switch too.
  11. Jan 17, 2017 at 8:33 PM
    #251
    Rabicano
    Rabicano Member
    Napa, CA
    2007 TRD OR, DCSB
    My '07 was only blowing on the highest speed. I was going deaf from listening to the radio so loud. Wish I had found this thread before buying a used climate control panel from a junk yard (I assumed it was the fan speed switch, it wasn't).
    Bought these two parts on Amazon for about $50 and installed them in about an hour. It works great now.
    Anyone want to buy a used climate control panel?
  12. Feb 3, 2017 at 3:08 PM
    #252
    SeafireXV
    SeafireXV Well-Known Member
    Olathe, KS
    2006 Tacoma TRD Sport ACLB
    So, I've just been through this very issue. Driving around in the cold without a heater will motivate just about anyone to figure it out... and quick!
    Fan stopped working, except on high. Then it stopped working altogether.
    Checked the resistor. It was fine. Checked the plug that the resistor plugs into...it was a little discolored on one pin, but not very bad. Pulled the glove compartment to access the cabin air filter. It was clean.
    While I had the filter out, I turned the fan on low, and nudged the fan with my finger...IT WORKED! I could then turn it on all speeds and it worked great! If I let it stop completely, though, turning it back on did nothing. The fan just sat there, stationary.
    I pulled the fan motor (It's simple...there's 3 screws on the bottom of the fan housing (5.5mm or 7/16 spcket required), and it pops right down and out. Unplug, and the fan motor is free.
    I took the fan apart and then the motor rear casing. Inside was FULL of copper dust and yuck from the commutator and brushes, and it was clogging up the fan and bushings, making it hard to turn. High pressure air from my compressor and it was all clean. Reassembled the whole thing, flipped the switch, and VOILA! It works!
    Easy, cheap, and effective fix. The commutator and brushes are showing a lot of wear, so I'll have to replace the fan unit at some point in the near future, but I see they're less than a hundred bucks at all the auto parts stores.
    Hope this helps...
  13. Feb 4, 2017 at 10:14 AM
    #253
    013tacoma
    013tacoma New Member
    Jeff
    2013 black tacoma
    Can anyone tell me where the 4 pin connector is located and how to get to it?
  14. Feb 12, 2017 at 3:27 PM
    #254
    425
    425 Well-Known Member
    Alex
    Hillsboro, OR
    2007 DCLB Sport
    Progressive AAL Banks Exhaust Leer 100R AFE CAI & TBS Kenwood Deck
    The 4 pin connector is under the blower motor under the glove box. To give you an idea, imagine sitting in the passenger seat and the connector and resistor should be about where your left foot is.
    Mine looks pretty bad, going to be fun to clean! I did wiggle it and it still works so the resistor is good.
  15. Feb 14, 2017 at 7:17 PM
    #255
    ionyota
    ionyota Well-Known Member
    2012 TRDOF DCSB
    OME lift, All-Pro UCAs, BFG KM2 pizza cutters
    I changed my blower motor resistor in April when I bought the truck used, and it failed again this week. Any ideas on what might be making the resistor fail repeatedly?
  16. Feb 16, 2017 at 8:56 PM
    #256
    Jimmyh
    SC
    2012 Prerunner SR5
    Are your connector(s) burned?
  17. Feb 17, 2017 at 5:29 AM
    #257
    ionyota
    2012 TRDOF DCSB
    Yes, appears that one of the 4 female connections is slightly burned.
    Assuming then that I should put in a new connector?
    Also, where is the blower fan located on the truck? Would like to take a look at it to see if it could use a quick clean. Thanks!!
  18. Feb 28, 2017 at 12:33 PM
    #258
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    Anyone got the part number for the fan relay?
  19. Mar 12, 2017 at 12:15 PM
    #259
    PhoenixLawnCare
    PhoenixLawnCare New Member
    Scott
    2008 Blue Tacoma TRO
    Auto Zone carries a kit to replace the resistor and wiring harness; part #973-582 for $32.99.
  20. Apr 2, 2017 at 8:36 PM
    #260
    Gordon-Gekko
    Gordon-Gekko Member
    Fort Lauderdale, Florida
    08 2.7 PreRunner SR5
    Ivan Stewart Wheels, RollBak Tonneau, Hellwig Rear Sway Bar, URD Short Throw Shifter, LC Engineering Header, Fumoto F-103, WT SW Deflectors
    The fan motor on my 2008 Tacoma stopped working yesterday on all settings except full blast. After searching around, I found this excellent write up by Aaron Linsdau ( click HERE ) that goes through all of the possible fixes: 1) new resistor pack, 2) new connector/cleaning connector pins and 3) removing the fan motor, disassembling the motor, cleaning the motor, re-assembly and re-install.
    After reading his write up I jumped right to #3 as I didn't have any replacement parts ( resistor or new connector). After removing the fan motor from under the dash (very simple), then disassembling the motor ( not so easy but do-able if you are mechanically inclined - I found the same problem he mentions: wear on the copper commutator and carbon brushes inside the fan motor which coats the inside of the motor with fine copper and carbon dust. The spring loaded carbon brushes inside the motor press against the copper commutator and wear both parts which results in a lot ( and I mean A LOT!!) of conductive material inside the motor that reduces the motors efficiency.
    The disassembly of the motor, cleaning the carbon/copper dust ( I used compressed air then alcohol and cotton swabs) and reassembly of the motor was a little challenging but it was worth it and now my fan works like new at all speeds without touching the resistor or the connector and pins.
    LGE RAW and LnL like this.
