Fan speed switch not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbmcmahon, Jan 17, 2010.
  1. Jun 10, 2019 at 11:23 PM
    #341
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes it is most likely a defective terminal at the connection to the resistor.
  2. Jun 11, 2019 at 5:13 AM
    #342
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    It has been a week and my new resistor and wiring harness are working great. I bought the Dorman kit from Amazon for $22.
    lo2hi likes this.
  3. Jun 19, 2019 at 2:45 PM
    #343
    Chanticleer
    Chanticleer New Member
    2008 Tacoma PreRunner SR5
    I'm a newbie on here with the same issue on my 2008 Tacoma - fan only works on high speed. Just ordered the Dorman kit from Amazon myself. Hoping it's not too complicated to replace.
  4. Jun 19, 2019 at 2:51 PM
    #344
    Mikehancho52
    Mikehancho52 Member
    15 4x4 access cab 4banger
    Slightly oversized tires
    Try resistor it's an easy fix
  5. Jun 19, 2019 at 2:52 PM
    #345
    JimIowa
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    Like others, I removed the passenger seat for my mobility. Removing the 2 screws that hold in the resister was fairly easy. Re-installing the back screw was challenging. Kinda blind and I was on my back just trying to feel my way around. I love this fix. Didn't know how much I use the lower fan speeds. Attached are some notes and photos from various posts here on TW.
    Jimmyh and Mikehancho52 like this.
  6. Jun 20, 2019 at 8:30 PM
    #346
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Wow, I totally just made sure the wires weren’t loose and it started working again. My symptoms were just blowing on HI.
  7. Jun 22, 2019 at 11:07 AM
    #347
    JimIowa
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    If your connector has a burnt spot like my did (see photo), then it is not just loose wires. One of my wires was also compromised. I wish you well that it was just loose wires, but just in case it starts acting up again.....IMG_20190622_1303496.jpg IMG_20190622_1304014.jpg
    lo2hi[QUOTED] likes this.
  8. Jun 22, 2019 at 7:40 PM
    #348
    lo2hi
    Chiro
    Portland, Oregon
    Yep so far so good. This will be my next thing to inspect if it goes bad again.
  9. Jul 7, 2019 at 1:30 PM
    #349
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    The way you wired yours worked perfect for me. Thanks for taking time to write it up. This was the only thing I could find on how to rewrite the new plug. Thanks again!
  10. Jul 8, 2019 at 8:06 AM
    #350
    motopilot
    motopilot Well-Known Member
    Central FL
    '22 DC TRD SPORT
    Well finally did this as well. Thank you for all the postings. I bought the Dorman kit on Amazon about a month ago. Mine has been on/off working on only the high speed for sometime but recently it’s almost full time only. I didn’t replace the wires as they seemed ok and I was short on time. Just replaced the resistor and so far works. I’m a FL so need to have this working. Was a quick and easy fix, except for that rear screw.
  11. Jul 18, 2019 at 8:16 PM
    #351
    Nocturnal
    Nocturnal Active Member
    Hawaii
    n/a
    Has anyone actually fixed this permanently? I took my truck in and they replaced the resistor and it started happening about two weeks later.
    I took it in again and this time they said I had to change the blower motor and the wiring harness/connector. They wanted $500+ to do the change. I am hesitate to do it and only have it stop working a few week or months later.
  12. Jul 18, 2019 at 9:51 PM
    #352
    Muddinfun
    Muddinfun Well-Known Member
    The guys/girls at the shop are a bunch of morons. You made no mention of the resistor connector, so I'm gonna assume they didn't replace it. You have to replace the resistor and connector at the same time. It's about a 20 minute/2 beer job. 30 minutes if you make it a 3 beer job.
    $500 is highway robbery for whatever they plan on doing. Read here on TW and fix it yourself.
    Jimmyh likes this.
  13. Jul 22, 2019 at 8:39 AM
    #353
    happyabortion
    happyabortion Well-Known Member
    brian
    port arthur TX
    99 tacoma prerunner
    So was this the right way to wire the new square plug?
    Update :
    Wired it this way in my buddies truck and it worked great. Just fyi for anyone else with this issue on the new plug
  14. Aug 8, 2019 at 3:14 PM
    #354
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I know people are having issues with the fan switch only working on high. The problem with mine is that high does not work. All the other speeds to but not high. It blows out very little. I've looked at the connector and nothing looked burned.
    Any thoughts on whats going on or where to look next?
  15. Aug 15, 2019 at 7:04 PM
    #355
    mdsinatl
    mdsinatl New Member
    Atlanta, GA
    2011 Tacoma
    OK, so I've been banging my head against the wall the past two weeks because I purchased the latest resistor and square plug to fix the issue of my fan motor only running on high. None of the threads or Toyota dealerships I talked to had the right answers on how to wire this new square wire harness plug for my situation. So after trying many different ways, I landed on the wire combination below that gave me four distinctive fan motor speeds. The wire colors connected between the old wires and new wire harness make no rational sense and the pin out numbers between the old and new plug do not line up. But it works and hopefully this helps someone else fix their issue as there seems to be little information available right now on how to wire these new plugs and resistors (latest generation of Toyota OEM).
    My specific situation is I have a 2011 Tacoma with the flat plug and bad resistor. I replaced with the part numbers below. Results and situations may vary but the wire connections below worked for me.
    Blower Resistor Pt.# 87138-04070
    Wire harness Pt# 82141-04Q80
    Wire connections:
    Old wire harness color >>> new plug wire color
    Green/Yel >> White
    Blue/Black>>Green
    White/Blue>>White/Black
    White/Black>>Blue
    BillyWest12, soonenough and Jimmyh like this.
  16. Sep 8, 2019 at 7:13 PM
    #356
    GeorgiaG
    GeorgiaG Active Member
    2007 4x4 SR5 V6 Blue Tacoma
    So I've been scrolling for a little looking for the answer (look with your eyes and not your mouth, right?) but haven't been successful. I was having the issue of the switch only working on high two weeks ago, so I swapped out the resistor and ram bam thank you mam I was back in business. Today, two weeks later, the fan is back to only working on high. I assume this is a symptom of a larger issue, but I'm not savy enough to figure that junk out on my own.
    Any ideas? Thank you!
  17. Sep 8, 2019 at 7:20 PM
    #357
    Muddinfun
    You have to replace the resistor and the resistor wire connector at the same time. Otherwise, it's like treating 1 kid for lice in the 3rd grade classroom.
    GeorgiaG likes this.
  18. Sep 30, 2019 at 11:12 AM
    #358
    Choads
    Choads New Member
    Cody
    2013 TX Edition Tacoma 4X4
    Lift, Tires, PRC Chip
    So none of this made any sense with all the numbers and colors and letters. I went to Toyota today and worked it out with them. This is the proper way to hook it up. I agree that it does not make sense that you would have a larger gauge wire hooked to a smaller gauge wire. However, Toyota made it this way. Hooked mine up this way and it works like a champ. I attached the diagrams that the Shop foreman printed out for me. Hope this helps if anyone is still trying to figure it out.
    Old Harness -> -> New Harness
    White/Blue Stripe -> (Hi) -> Solid White
    White/Black Stripe -> (Lo) -> White/ Black Stripe
    Green/Yellow Stripe -> (M1) -> Solid Green
    Blue/Black Stripe -> (M2) -> Solid Blue
    Cowtown Taco, Muddinfun and GeorgiaG like this.
  19. Sep 30, 2019 at 1:32 PM
    #359
    Muddinfun
    Finally, somebody posted the correct wiring with documentation to back it up. So, you just match the white/black to white/black and then from there, you just ignore the stripe colors and match color to color.
    Good job Choads!
    Choads[QUOTED] and GeorgiaG like this.
  20. Sep 30, 2019 at 1:54 PM
    #360
    GeorgiaG
    and here I was just lining up the wires from left to with the clip oriented towards me... There's just no help for some people!
