Fan speed switch not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbmcmahon, Jan 17, 2010.
  1. Sep 4, 2022 at 4:58 PM
    #441
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
  2. Nov 30, 2022 at 4:00 PM
    #442
    stocko taco
    stocko taco Well-Known Member
    Az
    19 Nissan Armada
    Honda Accord OBS Chevy
    @erasedhammer
    NmapFE likes this.
  3. Jun 27, 2023 at 11:59 AM
    #443
    Cowtown Taco
    Cowtown Taco New Member
    2008 Silver Tacoma V6 SR5
    2" Lift, Eibach Stage 1 front and rear, Icon Add-a-Leaf 275/70/16 All-Terrain T/A KO2s, Black Fuel Rims Custom front grill and headlights. Touch screen stereo system. 6 foot bed with a custom bed frame for overlanding.
    Thanks to Choads for this post (#363) on this chat, I used his old to new wiring diagram to get through my project. My fan was nothing or high.
    I had replaced my resistor a couple years back with the cheaper Dorman resistor and it went, again. So, this time I used the Toyota parts....new resistor and harness. Followed the wiring above and it works perfectly. I'll post some pics here for all.
    The old stuff I took out:
    The parts from Toyota (in total $118 Canadian):
    New harness and resistor installed, I left osme extra wire in case I had to ever do it again, after this pic I taped it up and out of the way:
    lo2hi likes this.
  4. Aug 9, 2023 at 9:36 AM
    #444
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Hey guys 2008 TRD Sport here. have been part of the wiggle wire/plug trick crew for about 2 years now. Most recently the wiggle trick has not been working. I pulled the plug entirely and was surprised that when the fan was on high the air will still operate without this plug even plugged in ? Apologies but this is normal right? Also, I had been sensing the smell of burning wires lately and I sure hope that this is what the problem is. Ordered the cheap Amazon combo and will attempt DIY repair this weekend. Hoping for the best with upcoming So Cal heat wave. How far back do i need to cut on the old wires ? thanks everyone
  5. Aug 9, 2023 at 3:46 PM
    #445
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    When the switch is on high, it is essentially bypassing the resistor completely.
    4x4_Taquito likes this.
  6. Aug 9, 2023 at 4:29 PM
    #446
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    I have had the part for over a year but the job is such an awkward pain and have yet to do it.
    Instead it’s high or off.
  7. Aug 18, 2023 at 5:55 AM
    #447
    AJ1G
    AJ1G Active Member
    Stonington, CT
    2012 2.7L Auto 4X4 SR5 Access Cab
    I also had the intermittent loss of the lower speed fan settings. Found carbon tracking in the female side of the connector to the resistor block, specifically on the larger diameter (incoming 12 V power) conductor. Obviously a poor (loose) fit up of the pin and collar of the connection. Permanently fixed by inserting a shim made from a tiny piece of copper foil into the collar side to tighten up the connection. Cost less than 1 cent worth of material.
    Chris B. Stonington CT
  8. Aug 27, 2023 at 12:21 PM
    #448
    motorcyclejesse
    motorcyclejesse Active Member
    Jesse
    2013 Tacoma TRD Sport DCLB Superwhite
    This is so appreciated. My lower fan speeds stopped working so I checked the connector and found it was slightly yellowed on one plug connector. I added diaelectric grease, reconnected and everything is working again! It already had the TSB wiring done, but I guess the connections get loose and short out?
    Fingers crossed my problem is solved.
  9. Aug 28, 2023 at 6:22 AM
    #449
    AJ1G
    AJ1G Active Member
    Stonington, CT
    The connection doesn’t short out. When the mated tip and sleeve of a connector are loose, arcing and sparking will occur between the two and heat is generated that causes the discoloration of the affected conductor. Applying dielectric grease may work for a while but what’s really necessary is to ensure the two halves of the connector are in proper tight contact. A small piece of copper foil inserted into the collar side of the affected wire connector will ensure that proper contact is maintained.
  10. May 3, 2024 at 9:06 AM
    #450
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    So what should I do if I replace the resistor and 4 pin connector per this thread and the fan still doesn’t work in any speed? I didn’t have a fan intermittently for a few weeks now. No burn marks on anything.
  11. May 3, 2024 at 9:33 AM
    #451
    N919HJ
    Ohio
    Disregard, I just tapped on the bottom of the blower motor and it fired right up. I guess I should have read a little closer and would have save myself the time and money of replacing the resistor and connector. Now I guess I need to order a blower motor.
    Dm93 likes this.
  12. May 3, 2024 at 9:54 AM
    #452
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    N919HJ[QUOTED] likes this.
  13. Sep 10, 2024 at 1:18 PM
    #453
    asjkhadfg
    asjkhadfg Member
    t
    '09 TACO
    Big thanks for this thread. I swapped out my soviet-looking resistor with a new one and now I no longer have to use my blower on high
