Fan speed switch not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbmcmahon, Jan 17, 2010.
  1. May 8, 2011 at 7:44 PM
    #41
    ironman44bear
    ironman44bear "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    Fixed mine today, cleaned plug (was burnt like the other pics), applied some copper electical grease sh!t, and now works perfect. and to think I have been putting up with this for 3 years LOL
  2. May 9, 2011 at 8:49 AM
    #42
    HubbaBubbaGump
    HubbaBubbaGump Member
    Carlos
    Katy, Tx
    06 Prerunner SR5
    My blower started working only on high speed this weekend. I was just about to order a blower motor from ROCKAUTO, when came on here to check.....too funny.
    I will go check this out during my lunch hour.....I am curious what I will find......
    Just checked.....the connector has a burnt connection like this(pic from other thread)......but when I plugged it back in, it worked on all speeds....
  3. May 10, 2011 at 7:01 AM
    #43
    Cobra6
    Cobra6 Well-Known Member
    Beri
    Tennessee Valley
    '06 PreRunner SR5 TRD Sport
    I am right there with you - between me and my Dad, we have 6 Ford trucks and not had the problems with all of them put together that I have had with my Tacoma. If Ford had a truck the same size as a Tacoma it would be a viable option.
    None of the parts houses in town had the blower motor resistor, and the stealership had to order it yesterday - won't be in until Wednesday, only about $34, but still a hassle. Then I have to solder my overhead compass/temp display and figure out why my rear doors won't lock/unlock.
  4. May 11, 2011 at 11:16 AM
    #44
    Cobra6
    Beri
    Tennessee Valley
    This just keeps getting better - ordered the blower motor resistor (not in stock) Monday from the stealership - get a call back today that the part was not at the warehouse and not available.
    get another call that their may be a new part number, but part would not be available until 16 May.
    Why do I not have confidence that I will get it then?
    None of the parts house have the part or can get it - Car Stuff took my order last Saturday, but still no part shipped - I betting they don't have it either.
    92 degrees here today, and the fan doesn't work at all. Toyota is sucking wind right now.
    UPDATE - I got the resistor from Car-Stuff this afternoon - OEM part for $29.18 + shipping
  5. May 15, 2011 at 3:45 PM
    #45
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack.
    I just disconect and conect back the blower conector and everything started working againg.
  6. May 26, 2011 at 9:50 AM
    #46
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    so my fan just quit working on everything but high. when i call my service department, do i just ask for the resistor for the blower in the dash? or is there a specific name or model number i need to reference?
    btw, great post, very helpful.
  7. May 27, 2011 at 6:17 AM
    #47
    melsman
    melsman Member
    Central California
    '07 PreRunner SR5 TRD
    Hi ND,
    I would recommend first pulling the connector to the resistor, cleaning the burned conductor (it will be obvious), and then coating it with a film of "bulb grease". Reconnect it and test the blower. Also, change your cabin air filter.
    If these steps don't fix the problem, then contact your dealer (or go on-line) and replace the fan motor resistor.
    Most of the time, the resistor isn't the problem... it's the over-heated connector that corrodes over time.
    Melsman
  8. May 27, 2011 at 7:12 AM
    #48
    nd
    Nate
    Greenville, SC
    thanks for the response. i took a look yesterday, and my harness looks like hte one pictured above. I didn't clean it or do anything, just plugged it back in, and now everything works fine. why did you mention cleaning the cabin air filter?
  9. May 28, 2011 at 11:33 AM
    #49
    melsman
    melsman Member
    Central California
    Hi ND,
    My theory is that a dirty cabin air filter is a contributing factor (not necessarily a causal factor) to this issue. A clogged filter will significantly reduce the amount of air flowing over the resistor assembly, causing more heat build-up in the entire assembly - including the connector. This theory seems to be supported by the fact that the factory service manual recommends changing the Tacoma cabin air filter much more often than in their other vehicles.
    Resistors are pretty robust components, and if they're failing and/or the connectors are frying, then there's definitely a heat dissipation issue. And it doesn't take a degree in aerodynamics to conclude that a clogged filter in the process would cause a significant reduction in cooling air flow across the resistor assembly.
    Thus, my recommendation to change/check the cabin air filter. If you don't want to spend $2 million on a stealership filter, here's one at Rock Auto for $4.11. I bought 3 or 4 just like I do oil filters.
    Also, I also recommend dielectric grease ("bulb grease") to fight corrosion on the connector. Again, a small tube at Walmart is a couple of dollars.
    Melsman
  10. May 28, 2011 at 11:15 PM
    #50
    Cobra6
    Beri
    Tennessee Valley
    The dirty air cabin filter and burnt connections going to the resistor are one issue, but you also have problems with the blower motors chirping or ticking - they eventually can go out completely - as in my case - I had to replace mine at 77k miles.
  11. May 31, 2011 at 8:31 AM
    #51
    Dube295
    Dube295 Member
    Andre-Luc
    Canada, Ontario
    Trd Off Road
    -Rear diff Breather ( on is way ) -WeatherTech Floor Liner (on is way) -Trd quick shifter -Trd exhaust
    I got a 2011 tacoma ... andIwondering if that is just a feature for what ever reason ... When it's hot outside and let say at 3 o'clock after work it's pretty hot inside the truck (my truck is black) So start the truc a/c work fine but I need a lot of fresh air so put the fan a max and the fan stop working ...
    It only gonna work if I hold the switch pass max kinda 1 degre after ... the fan also stop if I press on the switch ... but as soon as the truck cool down ... (using the open windows technique the fan start working again ...
    So is it a great feature in 2011 to protect something or my switch is bad?
  12. Jun 3, 2011 at 5:05 PM
    #52
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    can somebody give me a llink to buy this and a part number please?
  13. Jun 4, 2011 at 10:23 AM
    #53
    melsman
    melsman Member
    Central California
    Hello JohnW,
    I'm not sure what part you mean by "this", but if you're talking about the blower motor resistor, do a Google search for "Toyota Tacoma Blower Motor Resistor W0133-1778922-OES" and you'll get tons of hits.
    Even Amazon has a listing here. Expect to pay around $30.
    If you're asking about the air filter, see my post above for a link.
    Good luck.
    Melsman
  14. Jun 25, 2011 at 12:06 PM
    #54
    blazedCBR
    blazedCBR Legally a baller
    Alan
    Tennessee
    06 Red PreRunner
    6000K HID Projectors, Pioneer head unit, Pioneer speakers all around, tinted, can't wait for my lift and new shoes!
    Wow I'm so glad I found this thread. Between this and the shltty soldering job in the temp gauge/compass I'm wondering wtf toyota doing these days.
  15. Jul 15, 2011 at 7:32 PM
    #55
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    I just ordered a replacement blower motor and 2 cabin filters from Rockauto. It is frustrating that I have an 07 with only 55000 miles on it and it already went out. Total cost delivered for everything was around 50 bucks. Not bad considering Toyota wants 200 bucks for just the motor and 25 bucks a pop for a cabin filter. Autozone wasn't much better on either one. My symptoms include the fan not working on any position but when I give the blower motor a gentle tap it kicks on. Hopefully it will keep working for a few days until the replacement gets here. I was thinking the it was a problem with the resistor at first since everyone seems to have that issue but I don't have the burn marks or other signs of problems that everyone else is describing. I am sure hoping this fixes the problem. Thanks TW. I will let you all know if this is the fix for me.
    06DrksdeTaco likes this.
  16. Jul 16, 2011 at 9:04 AM
    #56
    FTB530
    FTB530 Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    I replaced my resistor twice before i replaced the blower motor and resistor , then the new one stopped blowing unless on high setting,there is a few post on here about the wiring,it looks like the plug into the resistor gets hot and looks melted,i unplugged the resistor and could see the dark coloring in the plug,i took a small screw driver and scratched the contacts and then i pput some dielectic grease on the contacts ,so far 6 months and its it is workig fine,.seems like Toyota would have a recall on this to many people wiht the same problem.
  17. Jul 16, 2011 at 10:20 AM
    #57
    Dube295
    Dube295 Member
    Andre-Luc
    Canada, Ontario
    Trd Off Road
    mine on my 2011 truck the fan stop on Hi setting when it'S really hot inside the truck ... and it look like my probleme is more likely coming from the switch itself since if I holdthe switch pass the Hi setting the fan will work again...
  18. Aug 24, 2011 at 8:07 AM
    #58
    TacomaRebel
    TacomaRebel Member
    S. Mississippi
    07 PreRunner TRD OffRoad
    My fan blower on my 07 PreRunner stops working on lower speeds also. I can tap on the resistor and it will start back to working. I called my local dealer and this is a common problem. On Friday they had 2 of the parts, I went over there today and they were sold out. The parts guy said that one of the techs had came up with a solution. If one of the pins on the connector is burnt or melted then what they do is replace that pin & part of the wire with a heavy gauge wire that comes from a connector part that they sell for around $12. The resistor is $38 plus tax. So about $50 in parts.
    He called the service dept, but they didn't know about it. But estimated it would take about 2 hours and cost around $200 for a 10 minute solder job. Parts guy said that he knows that one of the techs has done several of these and that I could talk to him tomorrow and decide if I think I can do it myself or want them to do it.
    It appears to be simple to do.
    My question is how will attach a heavier gauge wire to a smaller gauge wire prevent it from overheating? My thought is the wire would need to go all the way back to the source/beginning to do any good.
    If it is the wire that needs replacing only, would that mean that the resistor is still good? The pins on it are not burnt or melted only on the wire connector?
    If this is such a common problem along with the overhead temp/compass that some trucks come with, why doesn't Toyota issue a TSB and have these fixed?
    How do we complain to Toyota about these problems, so maybe they will fix it for those of us that the warranty has expired.
    Would love to hear opinions.
    One other thing: When I was coming back from the dealer, I decided to see if the fan would work with the resistor still unplugged from the blower. YES it will blow on high only and puts out cold air. I guess the high setting isn't controlled by the resistor?
  19. Aug 24, 2011 at 8:12 AM
    #59
    TacomaRebel
    TacomaRebel Member
    S. Mississippi
    What do you clean the connector with? Do you take it apart so that you can get to the whole connector?
    My resistor appears to be ok, just one of the pins on the connector wire appears burnt. My dealer parts dept, says they solder in a heavier gauge wire from a GM connector.
  20. Aug 25, 2011 at 6:16 PM
    #60
    porsgrunn
    porsgrunn New Member
    2005 Tacoma 4x4 Double Cab TRD Off Road
    I have a 2005 Tacoma, and have had the fan blowing on high only since year 2. The dealer has replaced the resistor twice. the 3rd time they showed me the burned connector and said it was my problem (out of warrenty) and wanted to replace my wiring harness for 1K+.
    You guys have described my problem to the tee.
    I still have High blowing but my connector and insulation on 2 of my wire melted. Any fix, other than replacing the wire harness, to replace the connector.
    One of the service people told me to go order the connector from GM!?! (What!!!! a GM part in a Toyota?!?) Aparently Toyota only has the full harness.
    Does anyone know if this GM part will work to replace the plug?
    Can i splice a new pigtail?
    Anyone have the GM part number?
