Fan speed switch not working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbmcmahon, Jan 17, 2010.
  1. Feb 1, 2013 at 7:36 AM
    #141
    mlafferty00
    mlafferty00 Member
    I'm at the dealership hoping to get rid of this annoying noise.
  2. Feb 1, 2013 at 7:39 AM
    #142
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The hum that these guys are talking about? This isn't about the chirp/ticking noise.
  3. Feb 2, 2013 at 4:47 AM
    #143
    mlafferty00
    mlafferty00 Member
    I think we are talking about the same noise. dealership tried to charge me 325. No thanks.
  4. Feb 2, 2013 at 5:40 AM
    #144
    mlafferty00
    mlafferty00 Member
    I'm going to try Headcase's suggestion first and try the WD-40 method. If not, I'll most likely try Gregman's suggestion with the new TSB blower motor resistor and pigtail install.:pccoffee:
    TRDsnb likes this.
  5. Feb 2, 2013 at 7:37 PM
    #145
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Bought the parts for the TSB (My truck is long out of warranty) and did the fix this afternoon. The insulation on the wire was broken and bare wire was showing through and there was a hole burned through the connector as well. So far so good.
  6. Feb 3, 2013 at 6:06 AM
    #146
    mlafferty00
    mlafferty00 Member
    Do you have the OEM part numbers for the blower resistor motor and pigtails?
  7. Feb 3, 2013 at 12:08 PM
    #147
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    No it's not a chirp tick, it is def in my blower motor for Air. It's a very steady hummm, I will record it and post it.
  8. Feb 4, 2013 at 5:55 AM
    #148
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    The part numbers are in the TSB. Also, look on post 141 of this thread and in the 2nd and third pics you will see the part numbers. (87138-04052 for the resistor and 82141-04M40 for the pigtail)
  9. Feb 5, 2013 at 6:27 AM
    #149
    mlafferty00
    mlafferty00 Member
    Alright. I'm going to get these parts ordered this week.
    Are pigtails necessary to replace with the new blower resistor?
  10. Feb 5, 2013 at 8:03 AM
    #150
    Sandman614
    Tim
    '06 SR5 Off Road
    I had posted numbers for a new plug that was cheap. OEM numbers are in the TSB as stated.
  11. Feb 5, 2013 at 10:03 AM
    #151
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    I would go ahead and do them both at the same time. My pigtail had burned through the connector and part of the wire was bare as well. My thinking is if you are going to do it, do it right the first time so you don't have to do it again.
  12. Feb 6, 2013 at 3:55 AM
    #152
    mlafferty00
    mlafferty00 Member
    thanks for the info.
  13. Mar 11, 2013 at 6:44 PM
    #153
    RobbyBobbySWBlue
    RobbyBobbySWBlue Member
    Rob
    St. Peters
    07 PreRunner SWB TRD
    Bilsteins 1.75, FJ TRD Black rims, wet okol, homemade Satoshi grill, BHLM
    This sounds exactly what is going on with my 2007 will post results as soon as I fix my connections
  14. Mar 15, 2013 at 9:53 AM
    #154
    drcarp
    drcarp Member
    David
    Georgia
    07 Tacoma TRD Offroad
    My blower motor quit working on all speeds. Could this be the problem if it's not a fuse? 2007 tacoma.
  15. Apr 10, 2013 at 4:16 PM
    #155
    a56kuser
    a56kuser Member
    *EDIT*
    Someone claimed it. Thanks.
  16. Apr 10, 2013 at 5:29 PM
    #156
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    If it was a few weeks ago.... Anyway, sincere commendation for being so generous! Someone will snag it, I'm sure. If not, try the Pay It Forward thread.
    TRDsnb likes this.
  17. Apr 14, 2013 at 10:05 AM
    #157
    drcarp
    drcarp Member
    David
    Georgia
    Nevermind, I changed it, it works now.
  18. Apr 24, 2013 at 6:55 PM
    #158
    Tim Buckley
    Tim Buckley Member
    Tim
    Houston
    '13 SR5 Texas Edition 4X4
    TRD skid plate
    My fan just started acting up a few weeks ago. Played with the wires going to the resistor and tapped the blower motor and imagine that. POS started working. Ordering a new resistor from rock auto and am going to try to clean up the wires. This is my first Toyota, can't say I'm impressed... Still upset about my truck lunging forward at stop lights.
  19. May 9, 2013 at 10:02 AM
    #159
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Have the same symptoms (fan only working on high setting) on my '07 since last summer. Checked the wiring harness and the white/blue wire is discolored (burned). I can see that without even removing anything. Wiggling the wire results in getting all the fan speed settings back. I suspect it won't last for very long.
    I will be ordering parts from the TSB and hopefully the fix will go smoothly as it seems to be the case for everyone.
    I already did the overhead temp/compass display re-soldering couple of summers ago. Small things like these happening every once in a while are disappointing and annoying on a not too old truck. Thanks TW once again.
  20. Jun 21, 2013 at 12:30 PM
    #160
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    I let this go on for about 15k miles. It got to the point even after I regreased the pins it wouldn't take long for another outage to occur. I was done.
    I had the dealer do the TSB for me. I printed out the TSB and they followed it to the letter. Yeah I didn't feel like crawling under the dash and crimping wires so I paid for a younger back at the dealer to do it for me. Cost me about $250 but the end result was great.
    Interesting to note that all four of the wires had discoloration from heat - it was only one wire the first time I looked at it. I wonder at what point the insulation would have fully melted and caused a much bigger problem?
