Fan Switch issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emglishe30, Jun 11, 2020.
  1. Jun 11, 2020 at 9:58 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    2010 Tacoma. Fan only works on 1st, 2nd, and 4th setting. 3rd setting blows like it’s in the 1st setting. I replaced the resistor and still the same. Took out the hvac control panel and everything looks fine. Check the harness under the dash and looks ok as well, no browning anywhere. Anyone have any thoughts? Thanks.
  2. Jun 12, 2020 at 1:30 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I fixed that same issue on mine. It was the #3 plug on the resistor connector. Mine was corroded. Used a mini file to remove corrosion, and a mini pick to bend the tab back into place. All fan settings now work. Toyota must be making a killing selling resistors, when in the majority of cases, it's corroded connectors that are at fault. I also bought a resistor way back when. I put a schematic on another fan thread that shows how to test the resistor.
    Jimmyh likes this.
  3. Dec 2, 2022 at 11:57 AM
    alextuco
    alextuco New Member
    Alex
    2011 Tacoma Pre-Runner
    Can you show the link to that thread? trying to fix my third setting as well.
  4. Dec 2, 2022 at 12:33 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter likes this.
