fan switches from recirc air to outside air automatically.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skweezal, Jan 15, 2014.
  1. Jan 15, 2014 at 8:10 PM
    skweezal
    skweezal [OP] Well-Known Member
    I have a 2013 Tacoma dbl cab. When it's cold in the mornings, I turn on the heater and fan and use it on recirc air to keep the heat in the cab. After (exactly!) three minutes, it automatically switches to outside/COLD air. It seems to be set on some sort of timer.
    I would love to disable this timer if possible so I can manually switch from outside to inside air.
    thanks
  2. Jan 15, 2014 at 8:12 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    instructions are in the manual. mine is a 2013 and I deactivated it
  3. Jan 15, 2014 at 8:13 PM
    Payduck
    Payduck Member
    Tujunga, CA
    2013 Tacoma Prerunner 4cyl Black
    I had this problem a while ago and i was very confused. It will do that automatically when the outside temp is below 50 if i remember correctly.
    To turn it off, hold the recirc button for 3 seconds.
  4. Jan 15, 2014 at 8:14 PM
    skweezal
    Thanks!! I will definitely try that tomorrow morning!! :)
  5. Jan 15, 2014 at 8:14 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Yeah it does switch to outside air automatically, I can't remember why. You can disable it, but it's only per key cycle IIRC. There's info on it in your owners manual on the specifics though.
  6. Jan 15, 2014 at 8:15 PM
    skweezal
    Thank you so much!! :)
  7. Jan 15, 2014 at 8:18 PM
    ramonortiz55
    Ramon
    Texas
    stock
    per key cycle?
    mine fixed permanently. .
  8. Jan 15, 2014 at 8:19 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Well there's always 20% outside air entering the cab(by law, to introduce oxygen into the cab).
    So you put it on recirc. And after 180 seconds, the light on the button goes out?
