Fan
Discussion in '4 Cylinder' started by labman626, Dec 11, 2013.
  1. Dec 11, 2013 at 6:40 AM
    labman626
    labman626 [OP] Member
    My heater and ac fan has seem to stop working. Everything turns on I can feel it get hot and cold but no air blowing. Is it the fan? How can I check to see what needs to be replaced? Any help thanks!
  2. Dec 12, 2013 at 7:56 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    I'm posting a reply, cause no one else has so far.
    You are right, either the fan is out...or it is not receiving electricity (ie the control knob is broken, or some other electrical problem).
    Not sure how you would properly trouble shoot it, but you could get an electrical tester and, with the fan control knob on one of the speed positions, test the positive and negative wires at the fan and see if you are getting any 'juice'
  3. Dec 21, 2013 at 4:00 AM
    sHiBby
    sHiBby Well-Known Member
    Jeff
    Laveen, AZ
    05 PreRunner Sr5
    Well I've just recently have had the problem, I'm going to try to fix it. I've read some threads here in the forum. It could be your blower motor as some peoples go out.
  4. Dec 22, 2013 at 7:49 AM
    Hansel
    Glenn
    Arizona
    base
    2X what sHiBby posted. in my previous post, instead of "fan" I actually should have written fan 'blower motor'
