Fast 4x4 swap question!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Jan 29, 2017.
  1. Jan 29, 2017 at 8:06 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Can i go ahead and put the front diff, CVs, and hubs/spindles on without removing the stock 2x4 tranny? Looking at doing this swap in slow steps so i can use the truck as much as possible while doing work on it.
  2. Jan 29, 2017 at 8:10 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    I'm looking into this as well. You'll need the output shaft for the 4x4 tranny if you wish to keep your transmission
    You'll also need a front drive shaft (maybe rear too)
    Edit: I misread, thought you planned on keeping your 2wd tranny. Anywho! Good luck, I'm trying to find the parts also.
  3. Jan 29, 2017 at 8:11 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Yes you can install the front end first, just make sure diff actuator is off or hubs are unlocked.. reduce pointless wear
    TacomaJunkie8691 and YotaGurlIAm like this.
  4. Jan 29, 2017 at 10:33 PM
    Kyle N
    Kyle N Active Member
    You can also install the diff alone if needed. I did my trans/tcase and diff first then took a few more months to get the rest of the parts.
  5. Jan 30, 2017 at 7:43 AM
    Nomadic
    Nomadic Active Member
    Ash
    04 Xtra Cab
    hey if you need parts for this conversion I have a whole set up that I was going to put into my prerunner before a drunk decided to use me as target practice. Hit me up I got literally everything.
    Captain Magma and YotaGurlIAm like this.
  6. Jan 30, 2017 at 8:35 PM
    MstrYota
    MstrYota Great balls of fire!
    Daniel
    Ventura County, CA
    2000 TRD 4x4 Prerunner/1998 TRD 4x4
    Too much but not enough!
    Are you going with manual or add hubs?
