Fast Signals
Discussion in 'New Members' started by taylortrev, May 27, 2013.
  1. May 27, 2013 at 8:32 PM
    taylortrev
    taylortrev [OP] New Member
    Taylor
    lift kid after market rims and tires
    I put LED lights in my 2010 Tacoma TRD Sport and my signals are alot faster now. Is this normal?
  2. May 27, 2013 at 8:34 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    this is how the truck tells you a bulb in the turn signals is blown. You need resistors.
  3. May 27, 2013 at 8:45 PM
    taylortrev
    Taylor
    thanks but bulbs work tho ?where do i have to put resisitors
  4. May 27, 2013 at 8:47 PM
    2000GTacoma
    Snow Hill NC
    Its because leds pull less power. Therefore because so little current is being pulled the system sees it as a blown bulb. As for resistors search tw I am pretty sure a write is around somewhere.
  5. May 27, 2013 at 8:49 PM
    taylortrev
    Taylor
    thankyou
  6. May 29, 2013 at 7:10 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Welcome
  7. Jun 1, 2013 at 9:10 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic/NW Arkansas
    '01 TRD Off-Road
    Lots 'o stuff. Look at my build! -->
    Just get a new turn signal relay that works with LED bulbs. That's what I did and it has the same result as resonators, but is much easier. Just unplug the old relay and insert the one for LED
