Fasten Seat Belt Light stays on...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tribull, Apr 18, 2013.
  1. Apr 18, 2013 at 7:07 AM
    Tribull
    Tribull [OP] Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    A quick history: I bought this truck ('02 PreRunner X-Cab) with a rebuilt title. It had been t-boned on the driver-side and completely rebuilt. Everything works great, except for the damned Fasten Seat Belt light! Well, that and the retractor in my seatbelt doesn't work anymore. Does anyone know where the sensors are that I can look for? I'm considering ordering a whole new assembly for about $150 shipped. That may fix the problem, but I'm just not sure I'll probably DynaMat that rear quarter panel while I'm changing it out. Any ideas?
  2. Apr 18, 2013 at 7:35 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Seat belt light ....
    There should be a wire going from the floor to the underside of the seat. Locate it and make sure its connected. You may have to remove the seat to locate the plug on the seat.
  3. Apr 18, 2013 at 9:39 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Put on your seatbelt.
  4. Apr 18, 2013 at 9:45 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    If the wire under the seat isn't connected the light doesn't come on at all. So your problem is most likely the switch.
    If you can take apart the female part of the harness that the seat belt clicks into (the part bolted to the seat), then your problem is somewhere in there. Shouldn't be too difficult to figure out! It's a toyota after all.
  5. Apr 18, 2013 at 10:23 AM
    Tribull
    Little Rock, AR
    Now why didn't I think of that...;)
    I just went and looked at the anchor side. It's got some of those security screws in it, so I'll have to go find a driver for it. And as you can see by the beautiful electrical tape someone has been in there already doing...something...
  6. Apr 18, 2013 at 10:52 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    You can get those at your neighborhood ace hardware! :thumbsup: But if you're not terribly worried about the sensor, just disconnect the wire under the seat. Takes literally 5 seconds. Just don't forget to buckle up.
  7. Apr 18, 2013 at 11:03 AM
    Tribull
    Little Rock, AR
    I'll probably just disconnect it for now, then fix it when I order the whole shebang. Ah hell, who am I kidding? I'll forget all about it by then.
  8. Apr 19, 2013 at 7:03 AM
    Madjik_Man
    Colorado Front Range
    Do you always put your seatbelt on regardless of a light/chime telling you to?
    If so, just disconnect the wire clip underneath your seat.
    EDIT: nvm. I have to get better about reading past the 1st post before I post
  9. Apr 19, 2013 at 1:29 PM
    Tribull
    Little Rock, AR
    No worries Madjik.
    I went out on my lunch break today and unplugged, and noticed that the clip/plug was INCREDIBLY dirty. Like, I don't even know how a plug under a seat could get that dirty! Anyways, I cleaned it up a bit and plugged it back up...voila! Works like a charm.
