Fastening a Camper Shell
Discussion in 'Tonneau Covers, Caps and Shells' started by RustedTacos, Apr 28, 2021.
  1. Apr 28, 2021 at 12:26 PM
    RustedTacos
    RustedTacos [OP] Active Member
    What are the best clamps to fasten a camper shell to a second generation Tacoma with a 6' bed. How many of them should I use to fasten it down thoroughly? 4? 6? 8?
    Thanks!
  2. Apr 28, 2021 at 12:29 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    What does the manufacturer recommend?
  3. Apr 28, 2021 at 12:31 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    each brand had different hardware, some use a clamp set up and others use a bolt / j hook set up into the OE bed t-slot rails
    socalexpeditions likes this.
  4. Apr 28, 2021 at 12:46 PM
    RustedTacos
    This would be an A.R.E. camper shell. Not sure if they have a specific recommendation for a clamp type
  5. Apr 28, 2021 at 1:29 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I would get on their website and shoot them an email, if it were me. You can either grab it straight from the horses mouth, or you can collect the opinions of 20 bubbas.
    :D
    Aquatic Tacoma likes this.
  6. Apr 28, 2021 at 7:29 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The recent Leer caps have 4 anchor points, in the corners, that use straight bolts threaded into fittings on the accessory rails. I didn't think this was adequate, and I added 4 more clamps. You're going to need more than the recommended clamps (and also bed stiffeners) if you're going to put things on the roof such as racks and/or rooftop tents.
    RustedTacos[OP] likes this.
  7. Apr 28, 2021 at 7:48 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    My snugtop uses 6 that go through tabs in the shell lower lip and hook the bed rail tracks. I’d advise adding nylocks since the bolts can work loose otherwise.
  8. Apr 28, 2021 at 7:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Only thing I'll add is don't over-tighten the j-hooks. If the fiberglass gets bent down too far it can crack
  9. Apr 28, 2021 at 9:35 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    This is why I like the nylocks, they stay where you put them.
    RustedTacos[OP] and TacoEspecial like this.
  10. Apr 30, 2021 at 11:05 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    My ARE came with 4.
    I'm adding 4 more just a few inches next to the existing ones.
    Think I'll switch to the nylocks while I'm at, thanks for the tip Scott.
    RustedTacos[OP] and bagleboy like this.
  11. May 1, 2021 at 1:23 PM
    RustedTacos
    Thanks guys for the input. Do you by chance have a link to the NyLocks?
  12. May 1, 2021 at 1:28 PM
    jkauf
    jkauf Well-Known Member
    2013 Tacoma Supercharged - Stock
  13. May 1, 2021 at 4:12 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
  14. May 5, 2021 at 7:55 AM
    RustedTacos
    Thanks all -much appreciated
