fat bobs lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bEEn, Oct 2, 2014.
  1. Oct 2, 2014 at 9:33 AM
    bEEn
    bEEn [OP] New Member
    Benjamin
    Orange County
    2014 tacoma
    hey everyone, i have made the decision to get the fat bobs lift kit for my 14 reg cab tacoma 5 lugger and was wondering what would be the most optimal tire and rim size without having to regear. also which is better a short leaf or a longer leaf? what should i expect in terms of mpg when getting bigger rims and tires i am currently getting around 21-22 mpg right now with stock 15's and the 215 stock dunlop tires and also will i need shocks if i install the fat bobs if so i was thinking about the 5100 blisteins thanks all
  2. Oct 2, 2014 at 9:52 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    This from fat Bobs is a Spacer level Kit Toyota Tacoma 2WD 5 Lug Suspension 2.75" Lift Kit 2005-2014 You can use your stock OEM Front shocks If you go 16" Rims Tires are less expensive 265/75/16 will work
    also I think longer AAL is Better
